Go to page : 1, 2  Next
1Back to top Go down   New member with some troubles! Empty New member with some troubles! Sun Jun 24, 2018 11:08 am
jseaman
jseaman
Hi All,
I'm a total newcomer to the K series so need a bit of knowhow. I've just picked up a Grinnall Scorpion III that hasn't started for a number of years.
The engine is free to turn, all ignition systems now seem to be powering and the fuel system is pumping away right up to the fuel rail. When I crank on the key nothing happens which seems to be a break in the wire to the ignition barrel. Firing +12V onto the starter it will crank OK but no sign of life. All fuses are good.
I have no voltage at the injectors (all read 16 Ohms), has anyone got a photo of the FI relay? Obviously nothing is where it would normally be on a bike because this is a car and I'm struggling to find a few bits.
I'm struggling to find a complete wiring diagram, any pin outs available for the ECU or the plugs in pic 1 for ignition?
A few specific queries - what is the 2 pin plug on the coil packs for? (see pic 2)
There are two 5 pin connectors which are interchangeable, which is right?! (pic 3)
Thanks in advance
James
New member with some troubles! 310
New member with some troubles! 514a2210
New member with some troubles! 210
2Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 11:24 am
What K is your Scorpion based on?  I'm guessing K1100 from what looks to be a 50A alternator.
That two pin plug in pic 2 for a Powerlet socket for powering aux gear. (Like a cigarette lighter plug.) It can also be used to hook up a battery tender.
Those four terminal connectors look custom since in the factory wiring the colors usually match from one connector to its mate.
The one with the three yellow wires and a brown is the from the GPI (gear position indicator) switch on the transmission which tells the instrument cluster what gear the transmission is in.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/gpi/gpi.htm
3Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 11:27 am
You should also post up a pic of the whole Scorpion.
4Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 11:58 am
jseaman
jseaman
Many thanks for chipping in
It's a K1100 but I don't know what year and it seems there are quite a lot of differences!
So I can ignore the 2 pin plug for now, that's good to know
The GPI is one of the bits that works so I'll leave that alone!
Pic of the car is below:
New member with some troubles! 610
I was swaying towards ECU failure so I just pulled it off the car and it rattled!! I opened it up and found a cap flapping around so I've just ordered another one, I know it won't be as simple as just that but I'll start there.
Is there any kind of resource that shows the Motronic pin outs? I want to check the clutch/neutral start/kill switch is all in the right state
5Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 1:11 pm
Thanks for the pic. Always wanted to see one in person.
Clutch, neutral, start/kill is handled by the instrument cluster and right combo switch, not the Motronic.  If it's in neutral or the clutch is pulled in then the starter motor should spin up even without the Motronic connected.  But of course the Motronic is needed for it to fuel and fire.
Early K1100s have a different Motronic than later ones.
Early:
New member with some troubles! Img_2915
Late:
New member with some troubles! S-l1600
Which is yours?
6Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 1:29 pm
jseaman
jseaman
Neither Smile
New member with some troubles! 514a2310
Great thanks, so the fact I've got no voltage at the injectors is not likely to be any of that then?
As for the car, it's chassis #3 so quite special if I can make it go (which is hasn't for a long time!)
7Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 2:26 pm
The body tells us that it's an early one.
Some K1100s came with catalytic converters, some didn't.
All of the US ones are cat'd but I think yours might be a non-cat one.
8Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 4:06 pm
THIS site says that Bosch number is from a K1. Of course there is overlap in ECU on different BMW motorbikes. Is there a BMW number on it starting with 1 464 7XX, the 'XX' representing the remaining two digits?
Further research shows it to be a BMW part number 13 61 1 464 417, which supersedes to a number of other part numbers, all interchangeable.
13 61 1 464 479 the most recent part number
13 61 1 464 710
13 61 1 464 196, 288 & 289
Fits K1100 and K100-16V, prior to 7/93, when BMW eliminated the separate ignition amplifier. I have two extras in my spares supply, both function.
HERE'S a great link for deciphering Bosch/BMW ECU part numbers. Just add the main group number of 13, the subgroup number of 61 and then what BMW calls the 'seven digit unique identifier' X XXX XXX.
Last edited by Two Wheels Better on Sun Jun 24, 2018 5:24 pm; edited 4 times in total
9Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 4:37 pm
jseaman
jseaman
Thanks, the engine was originally a K100 8 valve apparently.
There is no BMW number on it sadly. Do you know if the K100 ECU could drive a K1100? I have no idea what they changed between them
It would be great to know what other ECU options I have as this has been chipped and is now damaged so is suspect!
I'd love to get a schematic of the ECU if anyone knows of one
10Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 5:29 pm
jseaman wrote:Thanks, the engine was originally a K100 8 valve apparently.
The ECU from a K100, because it uses a 'flapper' inside the airbox and is a totally different type of fuel injection known as LE-Jetronic, will not function in a K100-16V or a K1100. The latter are 'Motronic 2.1'.
See my list of part numbers and other details above for more info. There are several companies worldwide who will repair a damaged ECU. But I'll wager you can get a clean, used spare from eBay or a forum member locally for not much dosh.
11Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 5:32 pm
Please post a picture of the fuel injectors and throttle bodies and we'll be able to tell if it's a 2V or 4V motor.
I don't 100% know off the top of my head if 2V motor can be run with a 4V Motoronic but it's probably possible.
I know that Grinnell chipped those bikes which you can't do to a 2V L-Jetronic so that might be why they have a 4V Motronic running a 2V motor.
12Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 5:40 pm
duck wrote:Please post a picture of the fuel injectors and throttle bodies and we'll be able to tell if it's a 2V or 4V motor.
In my experience, one could, with the correct engine wiring loom, run Motronic 2.1 on an 8V engine as all the critical pick up points required are the same, though you might find a temperature sensor that has a different configuration to its connector. Of course, the 8V airbox guts would be redundant, but the ignition wiring plug is the same pattern. Only K1200RS/GT differ from K100/K1100 there.
As Duck suggests, to determine whether K100 8V or a 16V motor, describe the rubber intakes just above the throttle bodies. Are they rubber accordian-shaped, or smooth rubber 'tubes'?
13Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 5:55 pm
jseaman
jseaman
So I can use any of these:
13 61 1 464 479
13 61 1 464 710
13 61 1 464 196
13 61 1 464 288
13 61 1 464 289
Is that right?
And I must have a K1100 ECU then based on the AFM (is it MAP on the K1100?)
I'll do the cap repair myself, the PCB looks fine but it's the invisible issues that concern me.
It has a Grinnall 'Superchips' install.
See attached pic of the injectors and TB inlets, they are accordion shaped
New member with some troubles! 514a2311
14Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 6:06 pm
The injectors fire into the base of the TBs, not directly into the cylinder head port, so it's a K11 or K100-16V. There is no AFM on this model, only K75 & K100-8V. Yes, any of those ECU in my list, but click on the link in one of my previous posts to determine which other numbers you can use by crossing it from the Bosch number.
15Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 6:15 pm
jseaman
jseaman
Thanks, sorry for my ignorance but by K11 do you include K1100? I don't know the numbering at all yet? And how would I tell if it is  a K100 16V or 'K11'?
Sorry just gone through the link, lots of options there!
16Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jun 24, 2018 6:18 pm
jseaman wrote:Thanks, sorry for my ignorance but by K11 do you include K1100? I don't know the numbering at all yet? And how would I tell if it is  a K100 16V or 'K11'?
By K11 I mean K1100RS and K1100LT, but also interchangeable with K100-16V and K1 models. Stay away from K1100 from late '93 unless you wish to remove the separate ignition amplifier. Your part number suggests your trike has this, the earlier type. Without the ign amp it would then be using the later Motronic 2.1 as I have in my Big Block (shown elsewhere). This later ECU was used in catalyst/oxygen sensor equipped models.
17Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 5:36 am
jseaman
jseaman
Wow there are a lot of K numbers!! So a K11 refered to K1100xx, what is the difference between an RS and LT ECU? And the K100 and K1 are interchangeable also with the K11, why so many numbers?!
Any idea how I work out what year my current engine is? Mine does have the separate ICU, I can't find any wiring diagrams for that either!
18Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 5:56 am
You know where the oil level sight glass and filler cap are? Under the filler cap there is a smooth upright section facing to the right hand side with the engine and engine code numbers stamped on it. Can you get at it to read them. I have a friend has a Scorpion but his is K1100 and you can access both. You might need to use phone to take a photo but the engine code is on that
19Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 6:14 am
jseaman
jseaman
Fantastic thanks, will take a look tonight
20Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 8:06 am
The K1 and K100RS4V are both 1,000 CC motors that use the same Motornic. They do not use the same Motronic as the K1100s though.
K1100s are 1,100 CCs.  The difference between the RS and LT is the frame and fairing but the motors and Motronic are the same. RS is the sport version and LT is the touring version. 93- and 94+ K1100s use different Motronics.
There is a date cast into the top of the engine block above the rear of the crankshaft but you need to remove the bottom half of the air box to see it.
New member with some troubles! Engine10
21Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 8:15 am
jseaman
jseaman
Brilliant, that's really useful, thanks
22Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 1:24 pm
jseaman
jseaman
OK so I have:
114EA 0293 2259
February 93?
23Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 3:18 pm
jseaman wrote:OK so I have:
114EA 0293 2259
February 93?
See link to help decipher the engine number:
https://www.k100-forum.com/t7276-complete-2v-engine#83840
Reading yours it says:
  • 11 = 1100cc
  • 4 = 4 cylinder
  • EA = emission code
  • 02 = manufactured in the 2nd week of the year (not "Feb" as you guessed)
  • 93 = 1993 (year of manufacture)
  • 2259 = number of engine off the production line in that week/year
New member with some troubles! Uk-log10 New member with some troubles! Sco-lo15
                              Paul  New member with some troubles! 905546712
24Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 5:13 pm
jseaman
jseaman
Great thank you for that (and indeed everyone who has been helpful on here!)
So at least I now know what I have, the only ECU I can find is this one:
https://www.ebay.co.uk/itm/BMW-K1100-LT-ECU/362261830507?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2763.l2649
And frustrated to miss this bargain the other day!
https://www.ebay.co.uk/itm/-/273292038674?nordt=true&orig_cvip=true&rt=nc&_trksid=p2047675.l10137
I'm still no closer to a pin out for the ECU or ICU sadly which is what I really need but will see how the ECU behaves with this new cap on later in the week
25Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 6:14 pm
New member with some troubles! 93_mot10
That's a 93 Motronic pinout I did some years ago.  Not 100% sure it's correct and it's probably for a cat'd US bike and I suspect yours may be non-cat.
26Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 6:18 pm
jseaman
jseaman
Thanks, from what I can tell, pin 1 is +12V and pin 2 is ground which doesn't tie up Sad
Mine doesn't have a cat now but no idea from the factory!
I've never struggled to find a wiring diagram for an ECU before, it makes things very tricky!
27Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jun 25, 2018 7:34 pm
Pin 12 is output to the diagnostic plug. On a bike that diagnostic plug would be a capped off (with a blue cap) three wire connector somewhere near the left top of the battery.
28Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Tue Jun 26, 2018 2:31 am
jseaman
jseaman
Thanks, I'll see if I can find that
29Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Wed Jun 27, 2018 7:07 pm
jseaman
jseaman
I finally had a bit of progress!
I've soldered the new cap onto the ECU and it did nothing as expected. I realised that I have an immobiliser in the loop which, whilst it appeared to be working (solenoid click when you put the fob on), could have been interfering. I got bold and ripped it all out only to find the two wires it interrupts were the starter signal and the 12V feed to the injectors.
The good news is I now have volts at the fuel injectors which is great. I need to do some more work to track the starter signal wire issue (hopefully I can get that resolved pretty swiftly). I'll rip out the rest of the alarm stuff (just LED and fob bits) then start working on spark.
Oh, and I found the diagnostic connector tucked away under a bit of the loom so that may come in handy too.
Maybe it will live again one day ...
30Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Thu Jun 28, 2018 6:50 pm
jseaman
jseaman
OK back to you guys again, hopefully you can help me move forward again.
I have soldered back in the original loom and I can crank the engine on the starter now. I have +12V at the spark plugs and +12V at the fuel injectors. Neither appear to be firing though.
I've done a crude voltage measurement on the hall sensor and I can see it changing state when cranking so it doesn't appear to be dead.
So, any ideas on where to go next. My thoughts currently are that if the hall sensors are doing their job I'm really only left with an ECU fault but all other ECU functions appear to be working.
31Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Thu Jun 28, 2018 8:24 pm
Considering that both functions rely on an earth being exended to make the circuit then have you checked that all (and there are quite a few) the brown earth wires are connected under the screw on the main spine tube under the tank. Have a good search around and make sure one has not escaped and is hiding in the mass of wires.
32Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 3:21 am
jseaman
jseaman
Thanks, I don't have a spine tube or the tank and the earths are all black but it's a good idea to have a hunt around them so will do so asap
33Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 7:09 am
Starter signal issue may be affected by what was done with the side stand and clutch switch wiring off the original bike.
If you have a working neutral light you should be k, but if you don't then you will need a working clutch switch or preferably a looped out clutch switch and possibly a looped out side stand switch. These are easy to do once you find the connectors......ones off broken switches work fine.
34Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 7:30 am
I have spare Motronics - let me know if you want to borrow one for troubleshooting.
FYI The one on eBay you are looking at has a broken mounting tab.
New member with some troubles! Ir-log10
 ;BMW; K1200RS Red
35Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 8:16 am
jseaman
jseaman
Yes the neutral light works correctly. From what little schematic I have found, the stand switch hits the fuel pump relay (which is working) and the clutch switch seems to go to the 'combined right' so I guess starter/kill switch which are working. That said, I'd really love to know which pin on the Motronic it is so I can actually measure it!
I did notice the broken tab but thanks. I'd be absolutely delighted to try an alternative ECU if you are willing to help out? Really appreciate the input as usual folks, thanks
36Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 10:21 am
PM me you address and I will send it to you
 ;BMW; K1200RS Red
37Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 10:36 am
The Motronic is not involved in getting power to the starter.
When the clutch is pulled in the clutch switch sends 12V to the start/kill switch via a black/green wire.
When the bike is in neutral the instrument cluster sends 12 to the start/kill switch via another black/green wire.
If either is sending 12V to the start/kill switch then pressing the start button sends 12V to the starter relay via a black/yellow wire.
38Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Fri Jun 29, 2018 10:47 am
jseaman
jseaman
Ah I see, thank you!
None of those wire colours tie up with what I'm seeing but the principle helps. There is a white wire with a red stripe that is the signal to the relay which, thinking about it, is straight from the ignition barrel so I guess I have bypassed both of those?
39Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sat Jun 30, 2018 1:24 pm
jseaman
jseaman
OK so I'm pretty much back to stock now I think. I fitted a new ignition module which made no difference.
I've got the hall signal right up to the ECU which changes voltage when cranking so the only thing I can think of between that pulse in and the injector/coil pulse out is the ECU itself. Whilst checking for spark I managed to get a little shock when turning the ignition off so I know everything is doing what it should except the signal to pulse the coils.
Fingers crossed Ringfad's ECU might confirm my suspicions...
40Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 6:06 am
Motronic tested yesterday , got distracted fixing a friends K1100RS (burst brake pipe) so missed the post.
Will try and get it posted tomorrow but at least you will have a known good one to play with.
 ;BMW; K1200RS Red
41Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 6:32 am
jseaman
jseaman
That's amazing, thank you very much for your help! I'm hanging all my hopes on that being my fix now!
42Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 6:56 am
I wonder if Ginnall's replacement ECU ICs deal with the fueling mismatch between the Motronic and the K100 engine?  Mike put that setup on a rig when he was building the Braun replica and the resulting power graph was - to say the least - a bit ugly.
Don't throw the old Motronic away. You may need those ICs to get the engine to run properly. If it fires up with Simon's Motronic but runs like the proverbial bag of shit, consider that might be the problem.
43Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 7:29 am
jseaman
jseaman
Today I changed every fuse in the car just in case. I found I can't read error codes out so the ECU is definitely suspect
For the TPS, when I ground pin 3 of the diagnostics connector, pin 1 is always +12V. Measuring the TPS signal at the ECU, I had 1.7V at idle (should be max 0.4V) to 4.7 at wide open. I've now set this to 0.38V at idle but still have +12V on pin 1 when pin 3 is grounded
On the plus side I have headlights and half of one side when indicating
44Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 7:29 am
jseaman
jseaman
Dai wrote:I wonder if Ginnall's replacement ECU ICs deal with the fueling mismatch between the Motronic and the K100 engine?  Mike put that setup on a rig when he was building the Braun replica and the resulting power graph was - to say the least - a bit ugly.
I certainly won't be throwing the old one out!
It looks like there is just one 'superchips' Grinnall chip that is fitted. What is the mismatch you refer to?
45Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 8:38 am
The fueling is simply wrong - it's mostly running rich IIRC.The Motronic is trying to feed a 4-valve engine whereas yours is a 2-valve engine. If you're refering to the 20-pin (?) IC in the middle of the PCB (it should be mounted in a socket), then yes, you'll need to fit this instead of the standard IC in Simon's unit.
Try Simon's unit first; if the engine runs then try swapping ICs. This will tell you if your IC is still okay. If it isn't, it's worth talking to Grinnall but they'll most likely want to charge a fortune if they still have the fueling map.
Simon - if you want to leave your Motronic with James, I have one here you can pick up next time you're passing. It's not a great deal of use to me and came with a bunch of 2-valve stuff.
46Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 9:22 am
Dai wrote:The fueling is simply wrong - it's mostly running rich IIRC.The Motronic is trying to feed a 4-valve engine whereas yours is a 2-valve engine.
In posts #20–#23, it seems to me the engine was identified as a K1100. scratch
47Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 10:00 am
Thanks Laitch - missed that - serves me right Very Happy . The comment about replacing the IC still applies though.
48Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Sun Jul 01, 2018 3:08 pm
jseaman
jseaman
Yes indeed it's an 1100 and that's exactly the process I was going to follow thanks
Can't get over how helpful you guys are, thanks!!
49Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jul 02, 2018 3:53 pm
The Motronic is on it's way, it is travelling from Dublin so may not be as quick as Royal Mail :-)
 ;BMW; K1200RS Red
50Back to top Go down   New member with some troubles! Empty Re: New member with some troubles! Mon Jul 02, 2018 4:23 pm
Ringfad wrote:The Motronic is on it's way, it is travelling from Dublin so may not be as quick as Royal Mail :-)
That should be there for Wednesday if it's in this evenings mail!.
