1 Question regarding fuel pressure Mon Jun 18, 2018 8:11 pm
tyrone
Hello all - new member here. I am riding a new-to-me 1988 K100RS Special Edition. Really enjoying this piece of German engineering. 135,000 KM on the clock.
I have been hunting down the cause of a strange idle issue. When firing the bike cold (fast idle on first click), the bike purrs perfectly. After riding for 5+ min and the bike comes up to operating temp some issues begin to arise. It seems that the bike is searching for idle, it hovers around 1000 RPM, only fluctuating very slighly at this speed. It also felt like it wanted to stall, and would stall occaionally while at stop lights. It needed either the fast idle on or some throttle to keep it from dying. It doesn't sound 'sewing machine' smooth as I have heard it described. I have done a few things from the recommedations in this forum which seemed to have helped.
1) Replaced fuel filter (installed correctly)
2) Replaced spark plugs (NGK non-resistive with proper screw on terminals)
3) Replaced plug leads (5k ohm ones from EME)
4) Cleaned all visible electrical connections under tank and grounds for corrosion with DeoxIT.
5) Checked for vac leaks around TB boots, TB ports, FPR hose, crankcase hose, oil filler, hose from air intake to plenum. Used propane and carb cleaner and can't find any noticable issues.
6) Fuel is returning to fuel tank as there are many ripples in tank when running and applying throttle.
7) A few new tanks of 91+ octane gas and a can of sea foam has been ran through the engine.
EDIT:: 8 ) checked valve clearances and they are within spec, none too tight.
This has made a big difference in overall performance but the surging, or unsteady idle still persists.
I then tried following Ned's advice running the bike with the TPS disconnected and I much prefer the ride with it disconnected. I then re-connected and adjusted it so it remains 'open'.
I also have set up a fuel pressure gauge on the tank to the fuel rail and measured fuel pressure. It was bouncing around like crazy around 20-40 PSI. I removed the FPR vacuum hose from TB#4 and capped everything off and now the pressure holds at a steady 34-36 PSI, at idle and over 3k RPM.
It seems removing the vacuum line from the FPR has eliminated the bike wanting to stall and really dip down when idling. It still tries to search and hunt at idle but it is MUCH better.
Something interesting I've noticed is when idling it holds a rock steady 36PSI but when I turn the bike off (kill switch to OFF positon and key out) the fuel pressure immedialty drops to 0PSI with the gauge positioned between the tank and fuel rail.
Is this instant loss of pressure considered normal if I have the FPR disconnected from the TB vacuum port? Is this a sign of a failing FPR?
I would appreciate any insight or ideas as to how to even out the idle. While it is completely fine off idle and up to redline, I would like to have the idle steady and even.
Thanks guys, you've helped me out so much already!
