Number of posts : 7963
The vacuum line at the bottom of the fuel pressure regulator is routed around to no 4 throttle body. You will see each of the throttle bodies has a little black rubber cap, no 4 instead of the cap has the vacuum line you describe. You should be able to get anything similar in an auto shop.
These are cheap, easily replaced [all push fit] and should be regarded as consumables because due to heat and location they dont last. Wise move is replace them on any K bike you buy.
I dont leave them on more than 2 or 3 years as they perish/crack and the bike runs like crap. The pipe will lead to bike running too rich and crappy.
While you are there you will see a Z shaped vent pipe that goes into the airbox, replace it to, it cracks too but you wont see the cracks and it also buggers the running.
PS We dont really have half wits around here but a few are cylindrically challenged for a missing cylinder. Then the full wits have to be nice to them because they really are the full shilling and have these nicer higher compression pistons that fit straight into a K100.....for more oomph. See, the K75 is actually a smoother ride....I dont own one but I did try to buy one and it was indeed a very smooth and impressive bike.
1971 Yamaha 125 YAS-1
