Number of posts : 7963
Swap the clips for the fuel line clips off the R bikes. They are screw type ss worm drive and suitable for the application. You need 6 of them and position the screw heads where they are accessible without moving stuff. Even the ones on the fuel pressure regulator can be accessed with a long screwdriver if you do this. Everything is then reusable. If you still have original fuel lines on your K bike do this and also put new 40mm longer fuel hoses on and all s good.
Also works for the other large diameter connections to the air box. Just make sure heads do not interfere with throttle mechanism.
1971 Yamaha 125 YAS-1
