1Back to top Go down   Fairing clips Empty Fairing clips Mon Mar 30, 2015 3:25 pm
DeRodster
DeRodster
right then,
so far I've purchased two type's from M'works.
Neither are the same as the original and won't fit.
the original one's I have are "brass" colour and the ''hinged end" is square
and fit's neatly over the thickness of the panel
Can someone tell me where I will get the correct type
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   Fairing clips Empty Re: Fairing clips Mon Mar 30, 2015 4:14 pm
Real OEM 1994 K1100LT, for example
The dealer. There are eight of 46 63 2 309 239 and six of 07 12 9 901 645, plus two of 61 13 1 925 120, all slightly different, between the main fairing panels on a late-model LT.
3Back to top Go down   Fairing clips Empty Re: Fairing clips Mon Mar 30, 2015 4:25 pm
DeRodster
DeRodster
thank you TWB,
I hadn't thought of that
alway's miss the obvious...that's me ;-)
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
