1 K1100RS (93) Engine cuts intermittently Mon May 07, 2018 4:53 pm
malcolmt
Hi Gents, I've not used the forum for many many moons. My K11 has developed an intermittent problem with the engine quitting with no warning. its totally intermittent, it may happen three times in a couple of hours, maybe once in a month. it doesn't seem related to road speed, engine revs, or ride time.
When it quits the tacho and speedo are still working. Pulling the clutch and hitting the starter button turns the engine, so the starter section of the electrics are till functioning.
Pulling the clutch so the engine stops spinning, the oil light comes on ( as you'd expect ) so that part of the electrics are OK. The temperature and fuel gauges continue to work OK.
Switching the kill switch off and on whilst your still moving in gear ( with the engine spinning ) produces something very odd. The lamp failure globe pulses, it fades and brightens at about 5hz .
if I switch the ignition off and on while its moving and in gear will clear the fault and she runs purrrrfectly till she dies the next time.
I don't think its a faulty side stand switch or flaky connection, it wouldn't reset every time ignition is turned off.
I've had the fairings off and opened every connection and cleaned with electronic cleaner. They all look good. Including the relay box under the tank. And when the fault occurs its not feasible to start poking about with a meter at the side of the road.
My gut feel is a relay is dropping out or maybe something locks up in the fuel injection controller.
I want to mount half a dozen LEDs on the handlebars and wire then to various circuits to see what looses power to cause the problem. and start eliminating the circuits.
Where I'd appreciate some help is with the wiring diagrams. I've got the clymer manual, and would appreciate more detail on the relays and switches. for example which terminals are the coil and contact of the relays and which wires are used the kill the engine from the right handlebar switch.
And who knows, maybe someone has seen this weird problem and has a solution.
Regards
Malcolm(t)
Parys
South Africa
Regards
Malcolm(t)
Parys
South Africa
A bike on the road is worth two in the shed
