1Back to top Go down   Fairing and Frankenstein Empty Fairing and Frankenstein Sat Mar 31, 2018 11:14 pm
fox1486
fox1486
This is the story of two bikes.  Two K bikes to be specific.  In fact two K100RT's, if you want to get down to facts.  One bike came mostly put together, didn't run, and has blue fairings.  The other is a little less put together, definitely isn't ready to run, doesn't have fairings, looks a little more pieced together, and has a green tank.
Meet "Fairing" and "Frankenstein"
Fairing and Frankenstein Fairin10
Now right off the bat, you may notice a few things wrong with this picture.  First off, Fairing and Frankstein have their tanks swapped.  Secondly, there seems to be two extension cords within Frankenstein's frame.  This is how they were purchased, and these are some of the things that I'm trying to figure out why! Haha.
Fairing and Frankenstein, were part of a package deal.  In short, the deal consisted of:
-(2) 1985 K100RT "complete" bikes (Fairing and Frankenstein)
-1985 K100 Frame with spare motor and Trans (Supposedly 30K miles, trim level unknown)
-1986 K75 Frame and spare motor (with parts such as tank, tail, some fairings, etc.)
-Boxes of parts.  Some new OEM, some used.
It seemed like a big project to take on, especially since I knew little about these bikes before the purchase.  I've quickly tried to dive into these forums for answers, and have had some success so far.  The following thread will follow the build of Fairing and Frankenstein.  Stay tuned...
2Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 01, 2018 12:15 am
Good luck mate
There are many wise people on here which will help you
Like they have help me
3Back to top Go down   Fairing and Frankenstein Empty My Fairing Lady Sun Apr 22, 2018 2:34 pm
fox1486
fox1486
***Disclaimer:  This is going to be a father/son project.  Any mention of "we" is referring to my father, and myself.
Well it seemed like the Fairing bike had the most potential to get up and running first.  The bike was basically complete, and did not require any reinstalling of missing parts (sans a front brake caliper).  However it was clear that it did not want to start.  After charging the battery, keying the ignition and cranking the starter, something was a miss.  The starter was turning over, but not the engine.  This lead us to the common Sprag Clutch issues that I only found after doing some research online.  Reading through some common remedies, one suggested to spray some type of cleaner into the 3 Holes in the side of the Sprag Clutch.  This could be seen after removing the crank case cover, and peering back at the Sprag.  Unfortunatley the Fairing bike was manufactured in August of 1984. So it's a 1985 model year bike, with a Hole-Less Sprag.  So that remedy was a no go.  But before tearing everything down to clean the Sprag by hand, everyone was suggesting that if we could just get the bike started, we could get it cleaned out with some high detergent oil.  Thankfully after doing a few tiresome bump starts down the side of our country road, she roared to life!
The decent amount of smoke coming out the tailpipe quickly subsided.  A good sign that there was no immediate issue, but the bike hadn't been running in some time.  It took a decent amount of time using the choke and throttle, to get the bike warmed up and running at idle without assistance.  We tweaked the master idler screw to help the bike idle right around 1K RPM.  We had a small celebration, of slow 100 foot rides back-and-forth in the first few gears.  Just a good feeling that we were making progress! cheers
I ran to the local hardware store to pickup some Rotella Diesel oil.  A quick oil change was in order, to clean off what we assumed to be a gunked-up Sprag Clutch with some of that high detergent oil.  While I was at it, I needed to "borrow" the left front caliper off of Frankenstein just so I could safely take Fairing up and down our road.  The oil seemed to help the Fairing, but more run time will still be a must .  But because the bike is not yet road trip worthy, we were only able to take short rides.  Just a little 1-2 mile runs back and forth.
Check out this link for our troubleshooting with the Sprag Clutch:
https://www.k100-forum.com/t13556-sprag-clutch-issue
Once we were able to get the Sprag Clutch issue pretty much ironed out, it was time for some general maintenance and cleanup.  I started to tear down the rear end of the bike, in order to complete the normal spline lubrication (final drive, drive shaft, and clutch splines).  I can tell you that due to our location in New York State, our biggest issue is going to be rust and corrosion.  As can be seen here, we've already run into some broken and corroded bolts:
Fairing and Frankenstein Img_6310
At the footpegs, the bike came with the top bolt already snapped off.  The other bolts took a lot of PB Blaster and time to work out.  Unfortunately it seems to be very common for these bolts to bend and warp.  Again this is an early production 1985 model, meaning that it has the rubber mounted peg plates.  Once the transmission comes out, we'll have to take some time in order to clean this up and hopefully remove all the broken bolts.  Because.... you know foot pegs would be helpful. Laughing
Moving along we finally removed the rear driveshaft:
Fairing and Frankenstein Img_6311
So far, so good with that one.
Fairing and Frankenstein Img_6312
Uh-oh.  I don't think I'm liking the looks of that end however.  Even though the bike didn't seem to have any issues, the driveshaft splines that mated to the final drive the did not look well.  Which was a little odd, since the final drive splines looked to be ok:
Fairing and Frankenstein Img_6313
Alright I don't know about "ok", but they certainly look better than the driveshaft counterpart.  In any event, I'm going to have to take a break from Fairing to look at Frankenstein's FD/DS.  It may be time to add some items to a parts list.  Fairing and Frankenstein 797640
Also, having a bit of trouble removing this plate that holds in the swingarm:
Fairing and Frankenstein Img_6314
Either way, progress is progress.  I'm looking forward to getting some things fixed on Fairing.
Fairing and Frankenstein Img_6315
Fairing and Frankenstein Img_6316
More to follow...
4Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 22, 2018 2:50 pm
The final drive input splines are harder than the drive shaft splines so it's normal that the majority of the wear is in the shaft.
For bikes that have sat for a long time it's a good idea to get the fuel injectors reconditioned.  Prices vary WIDELY on this service so do some research before selecting a shop.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/fis/fis.htm
5Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 22, 2018 3:02 pm
Right swing arm pivot:  Just work around the edges prying it out. Unless you're REALLY hard on it it is a tough part to damage. Once you get it out a little ways trying spinning it to loosen it up.
6Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 22, 2018 5:03 pm
FD splines: they're toast. Take a closer look at your picture and you'll see a small ledge at the base of each spline. They look good because they've worn evenly, but that ledge is the amount of wear in each spline.
R/H gearbox pivot: an 18" pipe wrench helps a lot Very Happy
7Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 22, 2018 6:15 pm
Dai wrote:R/H gearbox pivot: an 18" pipe wrench helps a lot Very Happy
Doesn't that leave marks in the aluminum of the RH pivot?  (Not that anyone will ever see since it's hidden behind the peg plate when the peg plate is reinstalled.)
8Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Sun Apr 22, 2018 8:45 pm
Deep ones Laughing . You get a good grip on the little so-and-so though.
9Back to top Go down   Fairing and Frankenstein Empty Feed my Frankenstein! Tue Apr 24, 2018 9:10 pm
fox1486
fox1486
Dai wrote:FD splines: they're toast. Take a closer look at your picture and you'll see a small ledge at the base of each spline. They look good because they've worn evenly, but that ledge is the amount of wear in each spline.
Dai, good catch on the FD Splines.  I took another look and you're correct.  Those look to have worn as well, although not as bad.  But from what I'm reading if you replace one, you should replace both ends.
In a way to take a break from the Fairing bike woes, creative a better base of comparison, and some just pour excitement, I decided to take some time to work on Frankenstein.
 Fairing and Frankenstein Franke10
I was actually pretty happy with the progress of the tear down.  Granted this bike was a little more torn down to begin with, but I actually ended up bypassing the status of the Fairing within a few hours.
Fairing and Frankenstein Img_6410
I was able to get the rear end removed, including the drive shaft and final drive.  I think that both looked a lot better, than it's Fairing bike counterpart.
Fairing and Frankenstein Img_6412
Frankenstein on top, Fairing on bottom.
Frankenstein also came with the cooling system and timing chain system removed.  This made things a little easier to remove, but also created more of a learning curve to reinstall.  Thankfully all the bolts, minus one, came out without too much of a fuss.  This includes every single foot peg mounting bolt (phew!).
As it stands now, the plan for Frankenstein is a Café Racer conversion.  Fairing will either be returned to stock and flipped, or my father will keep it.  I thought it would be a great bike for him, since he's now retired and has been motorcycle-less since the late 1970s.
Parts purchase list is adding up:
- (2) Clutch boot.
- Bellhousing guide bolts (to remove transmission)
- Clutch alignment tool (for clutch spline lube)
- Tube of Staburag
- Tube of Honda Moly 60
- Front left brembo brake for Frankenstein
- New Headgasket for Frankenstein (last owner had removed head at one point)
- Possibly "monkey nuts" for Fairing's alternator (seems to be loud there when revving)
I guess the next step is to start pricing out the best places for these parts. Fairing and Frankenstein 78846
10Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 12:19 am
I pull the transmission off and put it back on with the bike sitting on a sawhorse on the ground and me sitting on the ground under the rear of the frame.  I tried the guide bolts and they just get in the way so I don't use them. (I've taken 30 or more of these bikes apart and put at least 25 of them back together so I've done it a few times.  The reason I take more off than put on is that some bikes are destined to be parts bikes.)
PM me a list of the parts you're looking for.
You don't need a clutch alignment tool either, you can use the transmission to do that.  I have a clutch alignment tool but I seldom use it because it is not really necessary and in my experience using the transmission as your clutch alignment tool works better.
Here's a link:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchnospecial/clutchnospecial.htm
11Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 7:10 am
Yup - top shaft looks fine. Here's what you want for greasing the splines (clutch and driveshaft):
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=grease&search=SEARCH
or this:
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=optimol&search=SEARCH
Top item in both cases.
12Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 2:48 pm
fox1486
fox1486
duck wrote:I pull the transmission off and put it back on with the bike sitting on a sawhorse on the ground and me sitting on the ground under the rear of the frame.  I tried the guide bolts and they just get in the way so I don't use them. (I've taken 30 or more of these bikes apart and put at least 25 of them back together so I've done it a few times.  The reason I take more off than put on is that some bikes are destined to be parts bikes.)
Here's a link:
I appreciate the insight here.  I would be ok with not using the guide bolts.  But for $25-$30, the insurance of the clutch alignment tool is worth it to me.  I'm not as familiar with these bikes, and you have to hope you pull that transmission back perfectly straight without shifting the clutch plate.
13Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 2:49 pm
fox1486
fox1486
Dai wrote:Yup - top shaft looks fine. Here's what you want for greasing the splines (clutch and driveshaft):
or this:
I've been watching a lot of the Chris Harris videos.  He swears by the fact the only thing that should be used is the Staburags on the clutch splines.  Just curious why you are suggesting using the others linked?
14Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 3:07 pm
Per Paul Glaves (longtime K guru and ex BMW wrench) I use a 50/50 mix of Honda 60 and Wurth Sig 3000.  The Wurth stuff is incredibly STICKY and keeps the moly around longer.
15Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 3:12 pm
fox1486
fox1486
duck wrote:Per Paul Glaves (longtime K guru and ex BMW wrench) I use a 50/50 mix of Honda 60 and Wurth Sig 3000.  The Wurth stuff is incredibly STICKY and keeps the moly around longer.
Am I missing in the links you sent above, where to purchase the Wurth Sig 3000?
16Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 3:50 pm
I didn't link.
Get the Honda 60 on ebay
Here's a link for the Wurth SIG 3000: http://www.mgcycle.com/index.php?main_page=product_info&products_id=1914
It's 14 oz tube - way more than you could ever need.
One thing about the guide pins that gets in the way is that you need to tilt the transmission a little (can't remember which way - CW or CCW - off the top of my head) to get it past the frame when putting it on/taking it off.  If the guide pins are too long then they get in the way.  That's why I don't use them.  Once you get the transmission past that point you can just use some long hex head M8 bolts to guide it the rest of the way.  I do do that occasionally.
17Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 4:07 pm
Posting for general interest:
While I was looking for the Wurth stuff I came across this explanation from Paul Glaves as to why he recommends the Honda 60/Wurth 3000 mix:
Over the course of lots of splines on lots of bikes for lots of miles I have sought a better spline lubricant than had been available. BMW's recommendations were all over the place over time, ranging from copper anti-seize to Optimoly paste, to Stabarugs paste, to BMW #10 red grease (essentially Texaco Starplex). This latter stuff would melt, drip, and run in the cartridge on the shelf and was very poor for splines.
One tried and almost true alternative was Honda Moly 60 which is a moly paste with 60% powdered moly solids. My experience on K75/K100 driveshafts (which have a deserved reputation for significant wear) and on clutch hub splines on Airheads, K bikes, and Oilheads was that the HM60 dried out too quickly and lacked sufficient anti-corrosion properties. It also doesn't cushion as well as a sticky heavy grease.
Wurth SIG 3000 is a very sticky, heavy, Lithium based grease. It doesn't dry out, stays in place pretty well, has good anti-corrosion characteristics, and cushions things pretty well. But it lacks moly (MoS2 - Molybdenum disulfide) which provides excellent boundary layer lubrication.
I concluded that 60% moly wasn't necessary so mixed the two, 50-50, providing a still heavy sticky grease with 30% moly solids content. I used it for many years.
18Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 5:30 pm
brickrider2
brickrider2
And Matt Parkhouse of Airheads fame has been selling small quantities of that mix for many years.  I too have used it for more years/miles than I can recall.
My airhead has well over 100 k miles on the clock and the splines still look amazingly good. The bike is on course to outlast me by a huge margin.  Wink
19Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 7:12 pm
Looks like horses for courses. Here in the UK Staburags (sp?) isn't available without going to the US, but Optimol is. The last time I did a spline lube was 30 months and approx 30,000 miles ago and I still had to wipe the stuff off to check the splines this time. Before that, it was 12 months and 14,000 miles and again, about the same for the previous two spline lubes. It was the way that the Optimol stuck to everything in sight and needed a really good clean off during the annual spline lubes that persuaded me that I only needed to check every couple of years. I didn't mean to run on to 2.5 years but, as stated, I still had to wipe the stuff off to check the splines.
If you think about it, at the clutch the only pressure is rotational. The bevel drive gets the worst of it with both rotational and longitudinal movement (as it bounces up and down). At least with the bevel drive you can do a spline lube by undoing the four bolts that hold it to the swingarm and then pulling it gently backwards until you can see the splines. You can then apply more grease on the end of a screwdriver (heresy!!!).
20Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 9:03 pm
The rear drive spline does not get any longitudinal movement as the swing arm rotates because the front uni has the same centre. This has been demonstrated by sidecar Paul some years ago.
21Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 9:33 pm
Dai wrote:If you think about it, at the clutch the only pressure is rotational. The bevel drive gets the worst of it with both rotational and longitudinal movement (as it bounces up and down). At least with the bevel drive you can do a spline lube by undoing the four bolts that hold it to the swingarm and then pulling it gently backwards until you can see the splines. You can then apply more grease on the end of a screwdriver (heresy!!!).
What do you think happens when you pull in and release the clutch? If the clutch plate didn't move then BMW could just bolt it in and eliminate the need for splines.
And Moly grease is for friction under load - like when you let the clutch out while accelerating. If the clutch didn't move on the splines then all you would need is a high pressure grease.
22Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 10:04 pm
RicK G wrote:The rear drive spline does not get any longitudinal movement as the swing arm rotates because the front uni has the same centre. This has been demonstrated by sidecar Paul some years ago.
A U-joint at an angle changes length as it turns. The front splines have a clip in them so where do you think that change in length is accommodated?
23Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Wed Apr 25, 2018 11:16 pm
No they change speed
24Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Thu Apr 26, 2018 7:29 am
https://www.k100-forum.com/t3815-some-thoughts-on-rear-splines
25Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Thu Apr 26, 2018 8:03 am
Thanks for that link Laitch I am hopeless at finding those things.
26Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Thu Apr 26, 2018 8:15 am
This explains it fairly well. It certainly bought back some memories of tech college and all the study that I did to get my trade certificate and quite a bit more I have done since.
http://www.sdp-si.com/catalogs/D757-Couplings-Universal-Joints3.php
27Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Thu Apr 26, 2018 8:38 am
RicK G wrote:No they change speed
The change in speed and the change in length are directly related (caused by the "imperfection" of U-joint geometry) and one of the main reasons that FWD cars have CV joints.
"A U-type joint works fine when there is a very limited shaft angle variation (primary driveshaft on a RWD vehicle, for example). However, a U-type joint will cause the driven shaft to slightly change length and will create a speed (rotation rate) change between the input and output side of the joint when the shaft must change its angle by more than a couple of degrees."
Source: http://www.autoserviceprofessional.com/article/91844/cv-joint-tech-a-primer-on-constant-velocity-drive-joints-and-diagnostic-tips
Both the paralever and monolever drive trains have unclipped splines in order to accommodate it.  In the 2Vs at the final drive and in the 4Vs in the splines between the two halves of the drive shaft.
Putting the U-joint axes as close as possible to the swing arm axis does mitigate spline travel caused by the changing geometry as the rear end goes up and down but it can't keep the U-joint from changing length as it rotates.
28Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Thu Apr 26, 2018 9:48 am
Well there you are we are both right Laughing
29Back to top Go down   Fairing and Frankenstein Empty Working away... Thu May 31, 2018 10:16 pm
fox1486
fox1486
Still making some progress on the bikes in between life.  Had to order a few parts before being able to proceed.  Big shoutout and thank you to fellow member "Duck", who came through a few of the parts needed.  He was clear, honest, and a pleasure to transact with!  Fairing and Frankenstein 112350
After those parts came in from Duck (DS, FD, Caliper), I needed a few other odds and ends.  I placed an order through Motobins, for a complete engine gasket set, 2 clutch boots, clutch alignment tool, shim tool, and a couple fresh BMW tank badges.  Amazon came through with the Honda M-77 (Honda Moly 60 replacment), and I purchased the Wurth Sig 3000 from seemingly the only place available online.  The concentration then turned back to Fairing, as it's now making sense to complete one bike at a time.
By purchasing some longer bolts at a local hardware store, we cut the heads off them to act as transmission bolt guides.  They worked flawlessly, and made the job much easier!  After removing the transmission, we finally got a view of the clutch pack.  I apologize for the lack of photos at this point, but I was eager to get moving!
Fairing and Frankenstein Crank_10
We disassembled the clutch pack to find that the friction disc was in good shape.  One less issue to tackle.  It did seem as though the Rear Main Seal (RMS) had a healthy leak.  Good thing I purchased that engine gasket kit!  I tried to tidy up the bell housing, before we pulled the old seal.
Fairing and Frankenstein Bellho10
That RMS was in there pretty good!  A slide hammer ended up being victorious after about an hour or so of finessing it out.  The new RMS was a breeze to put in.  We reassembled the clutch pack, and reinstalled it to specs.
Now onto the reason we had taken this much apart in the first place... the infamous clutch spline lube!  Using a mixture that other members had mentioned in this post and others, I used a 50/50 mix of Honda M-77 with Wurth Sig 3000.
Fairing and Frankenstein Lube_m10
Man oh man is that combo sticky!
I then got into cleaning mode, and started to tackle the engine and transmission.
Fairing and Frankenstein Trans_11Fairing and Frankenstein Trans_10
Fairing and Frankenstein Painti10
Fairing and Frankenstein Crank_11
While you can't eat off them, the parts have come a long way in cleanliness!  Even though it would have been nice to repaint the driveline and motor, it seemed like overkill if I can just clean most of the crud off.  To throw a little color in though, I decided to paint the cam/crankcase covers.
But before we can proceed with reinstalling the transmission, those pesky snapped and seized bolts need to be dealt with!
Fairing and Frankenstein Foot_p10
First attempt was to weld a nut onto the bolts, in the hope that we could work them out.  No such luck.  We broke several welds, and neither bolt wanted to budge.  Not that we wanted to start drilling into them, but we had no choice.  We begun that process tonight and will have to finish that later on.
That's where we sit as of now.  I'm hoping once we reinstall the transmission, I can reassemble the rest of the driveline.  Next step would be to test the Blue tank fuel pump (as we ran it using the green tank), and reinstall all the fairings!
Getting closer and closer...
30Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Fri Jun 01, 2018 4:07 am
there is a rubber o ring between the output shaft and clutch pack retaining nut
it fits under a spacer and seals the engine from the clutch housing
in many cases this is the primary cause of oil in that area
hope you replaced this little but significant oil source whilst you were in there
31Back to top Go down   Fairing and Frankenstein Empty Re: Fairing and Frankenstein Fri Jun 01, 2018 10:01 am
fox1486
fox1486
charlie99 wrote:there is a rubber o ring between the output shaft and clutch pack retaining nut
I did replace it! Thanks for the heads up there.
Sent from Topic'it App
