1Back to top Go down   A party inside the shaft drive Empty A party inside the shaft drive Tue Mar 13, 2018 11:56 am
StefanMajonez
StefanMajonez
Hi!
I was riding around, minding my own business, when suddenly...
A party inside the shaft drive YHEgkUdLp41w7oYNW0CccyZvLohqMoqcufMXcYeBf8tX_IGVlbdBJwz72c_ElMkgeZO1Lr8ebu7SaOktXpkH1AOogJmncOCWSbld4vgOaa2J-Jt_-YKeyvFhkh7UOLq53CUHFiYsOkDQubAdF62fsjMTBw6LzQf5p-a-ode7Kkxka1vbdzGuKl3g6jThEGsn-eelJFyuD0dYUpjDKXpOfXmXDaFFdWiYcIPgAMmiEH0-jb8L8S1AHPskhO-B5nfE6p5uLxJJEKQDfrQER1RvIqj7FeFBMV_DSlIYhsqz8U-wjxWaZcNXL-1-eo7U-RpB-8iXFCakQn1atU1lgEMRHJ7aZW6d5BlQ5BYIUADDptgQvgTmQ6BvSjiLqx1whW4vHHw075rhPC6-GsVJgWM8LS5r7RO_95hZUF9tKAEY2ZC45GzbUdNcdkWkn7Sze1VhP0CsyNUI9EdBf6FBP8IreX2OjQTWQyjYpeIWz6n-C2_h7u9Upla87r6hfrldzoyjNbHzjU_uBrKnMmo1aoA1BFYPk88abd5mr3XTJFMIdA9Z0q3NNrendYddjpj1wtnnamEPrYlH5o8vZUxbViH7d5LSTkV8lYo350ulszc=w1219-h914-noA party inside the shaft drive EIEwcqnasNhFuS3KvgEb-G3nAOjmNEQ3IgcEtn6APGDpQQMjZcN-JkKWuigSOpdkcuEdnrsB1GtCDBVIGL_r5N1n0QQ3FxbQ_TJ9EdlK-FQrodyMwawCoO1yKzWlvsYThoPJvu9nMFjNtxl2Djz-_b_d8Ld_O5yNkyPGYwUL6m9vzOyjZpmT77xN9ld4DIU46Uiyv5vDd2P9k8jy2IP_2q44Jw4oNmmD0nTQgZtOJrvnEyIKESkneYkpM4xZBYvK2EDYkcXWChLF9ckh2c3ZpIufjl9Wy8zazzSJ6DQFeJnILXiikd-VhQZPlNUoz6cRUCwFR9Isvgm5jjCivi2vt2tK31uZIb0eKwHzu3komhPjd2H5A77vEbCeR-bj-4ir3wpT37sIpqEoZ7CiVGfMVVTGEUeynPbGzXPaRTpqxA_4Bys3tCzznkytQKjOtVxXHBRnqwY6Rw5upxJULbtJpceevy-vq8X2qpkutNXw5wmzyJkvdFGhbFnrDT5EYFJ0L9b0dYIlcx5o8xXjqcKV5RomH4Pe6hAv1iBiqqrpuR2g6hISdx3zEfI_QwyV-Xi0DHAvEbROViUK_7YpxY7aL-xD1JORiJgPEeLEO8U=w1219-h914-no
How f**ked am I and what should I be replacing?  Very Happy
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
2Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Tue Mar 13, 2018 12:25 pm
I suspect we are looking at the result of an improperly phased drive shaft.
Have you looked at the front end of the drive shaft?
At a minimum you need a swing arm and a drive shaft(possibly just the rear half).
Can you pull the shaft without removing the rear section?  It would be informative to see the phasing of the u-joints.
3Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Tue Mar 13, 2018 12:50 pm
StefanMajonez
StefanMajonez
Point-Seven-five wrote:I suspect we are looking at the result of an improperly phased drive shaft.
There you go.
A party inside the shaft drive 366AdWBzxwoQj3exT6AtlUGeKL77C4rltyyzVZ6wxxl5I3w7yaIhNaASl61ot1hlMXASdQGzCK6chLLGVCTEL5Bi9A8tH5EV573si84LyKSTOEmEq-wpgnAPK2cBuaEWE7mU8GSKnSRdJDBYQ8bPlQwYWInwFKKUS3nRbgoKNku8KoFxOihTIJxqidQwbQcP6t1ieG_eqCQMfiK86mR95VZyGgX1BwmCZw5PAul7LRwkcHpFogwmFh5SMHEmvpejVsQ8IAzf4PghQb78Jxi0szKrK6yKCL7jM_ioObz2JEQ8wNIMBnNKFjdLKG_GsNJ5JMg-FmQfPh0ELLexvNk8J6w9JrvId73yPV7uXBxe7DiYUBoXOdbWjiWBXXO1zamoQb4ghx4v_d7U9tmZ3aiJ5ho59Fd_GU_xZvPMb0gCng8T-VgKHyAfKrmRG53jHC9weOWK-ai_sk8RBlrrhpv8Bypvh-3GYkxTmlholn6E3xTpCIoaawC61M-RijBr9Yy8u9b071GHviC9OHKu4fL1wXjjA03I2YDlS_mCjdyZQuGxqRDs8NZ1j0qV2hespyOxAadkq9AKv6gsNRw7liasHKIdFpgjwQ7TxaqJlaA=w1219-h914-noA party inside the shaft drive HIOF1gE-BL3VwZ6oePpYWO-yeuvyslVDKw0T-iRjtCNRqRL9kgvmsDuKyrs-K-EqGtTmzEclWRlQmqSkp--kmOTtIgUGx5zLbqYWdpN4F3595kZJ7dyI3tPGu3knj61Lfa1unGHvDBo_pjyEfhDYV2Ssjpyu0ib6hV6mkatn2CIO3gNGKbrrnAoOoJYHPh4KAYP2TvDIOMl5CxCf20PMxGTqKpDA8ASQ-PCnMEGqfF0BHqsVVFNMSIHF08CunXn4V1Fqn7JEJcGL9vBxb5gTyT4nS6-nWScMUIpN8wCULgXftRa54ebClIU9SBTcWSH-vFWFx1wt5RuFVjZZvD578zBGxwSIOpY5UVXynKiRpCM7LuMJEiwUdcPMwEhJly1MhrnQ5C7DD1DqLSXPHxtgXxz4WlFQGOCQ3YvPPNB2hzRVPSh9uNrQvLIhY_PI5oFm4MBc5Cb25FmFdqlb1U9Mytuye8BaqLAmRs9jh-xpuBLDlkkZJUR4LV3EtpyC37UkyAVGfGv-UKiJuNQjWY2tYFWUm8au9AwF9b8rHfRiliQmZcWsOKwszlCKrbvFgJVwNK6Q0UWxGx_NfhoQYA_v-WNwEsDxU5DNzPMlNTQ=w686-h914-no
Here you have an additional photo of the swing arm itself - it looks operational to me, do you think that damage is small enough to just clean it up and use it?
The shaft is indeed a tiny bit out of phase, but would such a tiny shift cause this?
Just so everyone knows, I'm a K bike owner for a year now and this is the very first time I even pulled the rear wheel off by myself - I didn't need to do it yet. So any help or knowledge is appreciated.
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
4Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Tue Mar 13, 2018 1:05 pm
Point-Seven-five wrote: Can you pull the shaft without removing the rear section?  It would be informative to see the phasing of the u-joints.
For an illustration of phasing, click on this link.  In a  two-piece driveshaft, the yokes of the joints at its ends must be oriented in the same direction. In the link, the yokes at the ends of the driveshaft are aligned vertically.
5Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Tue Mar 13, 2018 9:41 pm
This will add to the link given. You said the shaft was a tiny bit out so this could explain what goes on
A party inside the shaft drive Drive_12
6Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 2:53 am
Can't see the original poster's photos - anyone else seeing them?
7Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 4:50 am
Gaz wrote:Can't see the original poster's photos - anyone else seeing them?
Not seeing them either. They must be out of phase.
8Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 5:40 am
Same here
Must admitt that i was here to see the horror show
9Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 5:45 pm
StefanMajonez
StefanMajonez
Photos are here, sorry about the confusion.
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
10Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 5:48 pm
StefanMajonez
StefanMajonez
Point-Seven-five wrote:At a minimum you need a swing arm and a drive shaft(possibly just the rear half).
I'm intrigued. Every online BMW store I visited sells the shaft as a single unit, I've never seen only the rear part. Where would I find such a thing?
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
11Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 7:40 pm
StefanMajonez wrote: Every online BMW store I visited sells the shaft as a single unit, I've never seen only the rear part. Where would I find such a thing?
eBay
12Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Fri Mar 16, 2018 10:55 pm
Laitch wrote: eBay
Usually sold as a complete unit even there.....try Bombay A party inside the shaft drive Skum_a10
13Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sat Mar 17, 2018 9:10 am
StefanMajonez
StefanMajonez
Inge K. wrote:
Laitch wrote: eBay
Actually on eBay a lot of people are selling only the front part of the shaft - exactly what I don't need Very Happy Also, shipping to Europe is costly, as most eBay sellers are in the US.
What do you mean by Bombay? My Google-fu didn't yield any results
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
14Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sat Mar 17, 2018 10:06 pm
Sorry......to much beer yesterday night.......to much mumbling in the bai.
15Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sun Mar 18, 2018 5:34 pm
StefanMajonez
StefanMajonez
Update: Decorations!
A party inside the shaft drive 20180312
A party inside the shaft drive 20180313
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
16Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sun Mar 25, 2018 7:16 am
StefanMajonez
StefanMajonez
Hi!
I'm reviving this post to ask another question, before I put my bike together.
A friend of mine who is an amateur mechanic person told me that a shaft drive needs to be balanced, and I see where he's coming from - an unbalanced shaft means vibration, and potential havoc on the transmission and the shaft itself.
But he told me that I should replace my shaft with a new one ASAP because of what's on the pictures below. Is he exaggerating, or are those scuff marks enough to warrant buying a new shaft (or having this one repaired in a machine shop, if possible)?
A party inside the shaft drive 110
A party inside the shaft drive 210
A party inside the shaft drive 310
A party inside the shaft drive 410
A party inside the shaft drive 510
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
17Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sun Mar 25, 2018 7:47 am
You've probably lost a few grams of weight; IMHO not enough to worry about.
18Back to top Go down   A party inside the shaft drive Empty Re: A party inside the shaft drive Sun Mar 25, 2018 8:03 am
StefanMajonez
StefanMajonez
Dai wrote:You've probably lost a few grams of weight; IMHO not enough to worry about.
In my estimation not even that; the flash camera makes it seem rough when in fact, moving your finger across the shaft, you can maybe feel the unevenness in 2 or 3 places.
The real question is, will the shaft be all happy and dandy at 200 km/h?  Very Happy
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
19Back to top Go down   A party inside the shaft drive Empty Driveshaft wear marks Sun Mar 25, 2018 7:42 pm
redrockmania
redrockmania
Stefan - Looking at your 3 photographs the wear marks look somewhat superficial. If you are concerned, first discuss with a K100 expert mechanic/technician if they might cause a balance/safety issue at 200kmh. As an engineering problem it looks like an easy job to machine with a lathe the part with the wear marks until they are gone. This will address any balance problems - if indeed they exist.
