2 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 4:10 am
The push rod goes down the middle of the main shaft and that seal goes into the main shaft end to prevent oil running down the shaft onto the clutch.
When you look at the seal which is in there the first instinct is that some fool put it in backwards but not so. The inside of the seal which has a tiny coil spring around the centre lip should face towards the rear of the bike.
3 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 5:10 am
4 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 6:27 am
The little clutch pushrod seal is a tricky bugger. Get it wrong and it ends up inside the gearbox. Disassemble to remove. Try to avoid replacing it if you can.
1971 Yamaha 125 YAS-1
5 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 7:42 am
Paul75 wrote:Ok great thank you. Does this mean it is situated in here?
No the other end of the shaft at the rear of the transmission.
6 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 8:41 am
@kustom_moto
Great thanks guys!
7 Re: Clutch actuation pushrod seal Tue Mar 20, 2018 8:42 am
Take a look at this link, Paul.RicK G wrote:Paul75 wrote:Ok great thank you. Does this mean it is situated in here?
8 clutch rod seal Tue Mar 20, 2018 1:08 pm
brickrider2
I just went through this with my airhead. That seal can indeed be tricky. The very tiny spring came off mine when I had the transmission on the bench. I didn't work out where the spring had come from until I had all the bits reassembled Now the seal is in place, sans spring. The good news is that I haven't oiled the new clutch disk - yet.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Clutch actuation pushrod seal
Similar topics
