7 Re: Fuel leak Mon Jan 15, 2018 7:49 am
Number of posts : 7963
Three lines,
Front of tank down to fuel pressure regulator which is in between the airbox and throttle bodies.
From fuel pressure regulator and then on to the rear end of the injector rail by the coils.
From front of injector rail up to the fuel tank. This one should also have insulation on it.
You definitely need the bottom half of the airbox off to get at the fuel pressure regulator. It's got two Allen bolts down to the top of the engine and they can be well seized. Copper slip them before going back.
If you have the original clamps getting them off the fuel pressure regulator can be tricky, I used a junior hacksaw blade and elbow grease.
When you are putting new ones on, the two at the front of the tank make them about 1 1/2" longer and service/maintenance is much easier.
The old ones will be very stuck if original, treat the tank spigots with care as you could snap them. I used a scalpel to cut them.
For the new lines I got the fuel pipe connectors for the R bikes, not cheap but they are suitable and screw on and off. 6 of them but it means maintenance or emergency repair are much easier.
The regular fuel line cannot be used INSIDE the tank. But if you get fuel line that is suitable for immersion in the tank you can use of for both.
Best bet is get as much fuel out of the tank before you do the job. A few short lengths [4] of fuel hose, maybe about 1 1/2" long with one end plugged with silicone can act as a protective plug on the rail and tank spigots. Use new off cuts, old ones may shed crap into your system.
While you are looking under the tank clean up your earths that are bolted to the centre frame tube. Also be sure your fan is working properly, if not its a good time to sort that too.
1971 Yamaha 125 YAS-1
