1 Starter bumping / pulsing but not rotating fully. Sun Jan 21, 2018 6:49 pm
PNWK100
Hey folks,
I'm working on getting an '85 K100 back up and running. It came to me disassembled but in good condition and "ran before it was disassembled".
I've recently wired up a Motogadget Motoscope Mini gauge (with "Combi" indicator lights) and their RFID mLock ignition. I did the daisy-chained 4 relay trick to get the neutral light to work. I used the supplied relay that came with the mLock ignition, pulled out the stock Bosch unit, and wired the new relay's ground into the ground terminal of the Bosch relay.
I've put everything back together to the best of my knowledge but I'm having starting issues. When I hit the starter button the starter gives me a half second bump/pulse every 1-2 seconds but doesn't fully turn over. The battery is fully charged and I've tried hooking up an engine-start jump pack that plugs into the wall. I still get the same bump/pulse action.
My questions:
1. What's the cause of the starter bumping but not turning over the motor?
2. Should the fuel pump be running in "accessory mode" like a car or only when the starter button is pressed?
My questions:
