1Back to top Go down   Rear Shock Empty Rear Shock Tue Oct 31, 2017 2:54 pm
tagaz
tagaz
Pardon me if this should be posted elsewhere.
What is the knurled knob on the bottom of this shock.
TIA for any and all replies,
Troy
Rear Shock 20171011
2Back to top Go down   Rear Shock Empty Re: Rear Shock Tue Oct 31, 2017 4:52 pm
BobT
BobT
Rebound damping adjustment.
3Back to top Go down   Rear Shock Empty Re: Rear Shock Tue Oct 31, 2017 4:52 pm
WoodyAUK75
WoodyAUK75
Judging by its position, I would say it is for draining or adding oil.
4Back to top Go down   Rear Shock Empty Re: Rear Shock Tue Oct 31, 2017 6:40 pm
BobT
BobT
WoodyAUK75 wrote:Judging by its position, I would say it is for draining or adding oil.
No definitely an adjustable damping knob. Not possible to add oil to the bottom of a shock.
5Back to top Go down   Rear Shock Empty Re: Rear Shock Tue Oct 31, 2017 7:19 pm
Bob's right.
6Back to top Go down   Rear Shock Empty Re: Rear Shock Tue Oct 31, 2017 10:34 pm
JR_K100RS
JR_K100RS
has it been mounted upside down ? , my aftermarket shock is the other way around , remembering all that logic about unsprung weight etc , fix the heavier moving part to the frame , the lighter moving part to the wheel
John Re
Melbourne Australia
7Back to top Go down   Rear Shock Empty Re: Rear Shock Wed Nov 01, 2017 1:29 am
JR_K100RS wrote:has it been mounted upside down ?
Different brands of shocks have differing mounting positions. A Progressive 465 gets mounted piston upward. The K75 riders manual shows the stock shock mounted piston downward.
8Back to top Go down   Rear Shock Empty Re: Rear Shock Wed Nov 01, 2017 4:36 am
BobT
BobT
Unsprung weight! Your'e having a laugh. This is a BMW K100 with a wheel that weighs in at twice what my Ducati does, and a shaft drive that might as well be made of cast iron.
The popular RAM shock is almost identical to the one in the picture and is mounted that way up.
9Back to top Go down   Rear Shock Empty Thank you for the replies Wed Nov 01, 2017 2:04 pm
tagaz
tagaz
Thanks to all who have replied.
I believe Bob is correct on this one.
I will experiment with turning it a bit each way and see what effect it has.
First must find the source of the fluid leak from the fd.
Troy
10Back to top Go down   Rear Shock Empty Re: Rear Shock Wed Nov 01, 2017 4:18 pm
BobT wrote:Unsprung weight! Your'e having a laugh. This is a BMW K100 with a wheel that weighs in at twice what my Ducati does, and a shaft drive that might as well be made of cast iron.
Exactly!!!
11Back to top Go down   Rear Shock Empty Re: Rear Shock Wed Nov 01, 2017 6:55 pm
JR_K100RS
JR_K100RS
Ouch ! , er yup I was having a laugh ! Embarassed
John Re
Melbourne Australia
12Back to top Go down   Rear Shock Empty Re: Rear Shock Sun Nov 26, 2017 5:10 pm
tagaz wrote:I will experiment with turning it a bit each way and see what effect it has.
Troy
I think you will find that turning the knurled knob to the left (anti-clockwise) will deliver a slightly softer or slower feel to the ride and to the right a firmer, or quicker response. I usually make a large adjustment rather than small steps so I can more accurately gage what changes my adjustment has rendered. With small steps you might not feel much change at all.
