1 How to remove and replace clutch cable on K100RT Thu 30 Nov 2017, 13:57
flyinglow
I have the fuel tank and air box removed on my 1985 K100RT so I thought I'd replace the clutch and throttle cables. I must be missing something easy because I don't see how to remove the clutch lever so I can remove the clutch cable. I screwed the adjuster in and removed the pivot screw but can't remove the lever so I can remove the cable? Thanks, jim
Dah! I didn't understand you need to remove the cable from the rear end clutch arm first to give enough slack for the front to be removed.
Last edited by flyinglow on Sat 02 Dec 2017, 10:15; edited 1 time in total (Reason for editing : Clicked check box for Notifications)
