1Back to top Go down   Odometer and Speedometer Repair Empty Odometer and Speedometer Repair Thu Sep 21, 2017 5:05 pm
flyinglow
flyinglow
I see Overseas Speedometer. www.speedometer.com,  listed in the Owner News mag.  I have looked at their web site and they list the K100 speedometer cluster as one they can repair.  Does anyone have experience using them?  What was the cost and repair time?  I'm looking at buying a 1985 K100
but the odometer isn't working.  Speedo is ok.
Thanks,  Jim
2Back to top Go down   Odometer and Speedometer Repair Empty Re: Odometer and Speedometer Repair Thu Sep 21, 2017 5:59 pm
If it is odometer gears (somewhat common failure) then you can replace those yourself. If there is something wrong with the odometer then you can also replace that yourself.
Palo Alto Speedometer also works on a K bike clusters. (I have no idea how much they charge.)
3Back to top Go down   Odometer and Speedometer Repair Empty Re: Odometer and Speedometer Repair Fri Sep 22, 2017 11:03 am
flyinglow wrote:I see Overseas Speedometer. www.speedometer.com,  listed in the Owner News mag.  I have looked at their web site and they list the K100 speedometer cluster as one they can repair.  Does anyone have experience using them?
There are several legitimate good reviews of Overseas Speedometer at MOTOBRICK.COM.
4Back to top Go down   Odometer and Speedometer Repair Empty Re: Odometer and Speedometer Repair Fri Sep 22, 2017 12:09 pm
flyinglow
flyinglow
Thanks for replies.  I will check out Palo Alto Speedometer and MotoBrick forum.   Do you know where the odometer gear can be purchased or do I purchase this from Overseas speedometer or Palo Alto.
5Back to top Go down   Odometer and Speedometer Repair Empty Re: Odometer and Speedometer Repair Fri Sep 22, 2017 12:50 pm
flyinglow wrote:  Do you know where the odometer gear can be purchased . . ..
Here's one source, with an unlikely name. Smile
