1Back to top Go down   Valve shim replacement Empty Valve shim replacement Sat Aug 12, 2017 7:08 am
Hello all, I need a couple of bucket shims for my k1100LT 2.75 mm and 2.80 mm to replace a pair of 2.85's which make the valves too tight.  Happy to pay or exchange etc
Cheers Klompy xxxxx. 0414231985
KKlompy Valve shim replacement 2854237993
Valve shim replacement Au-log10
2Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Sat Aug 12, 2017 9:38 am
I will have a look tomorrow John. I am fairly sure I have 2.80 and I probably have the 2.75.
Get back tomorrow morning and ring ya
3Back to top Go down   Valve shim replacement Empty Shims Sun Aug 13, 2017 4:43 am
Thanks mate. Shame there aren't interchangeables with Kawasaki etc I have order from motobins which are the cheapest. Probs be good to have a library of em to exchange etc. will keep eyes open should a box of goodies turn up.
4Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Sun Aug 13, 2017 8:14 am
I have got them PM your address and I'll get them off in morning. Did try to ring but you must have been in church.
5Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Mon Aug 14, 2017 9:04 am
Precision Shims in Melbourne have the shims you need at a good price.
 Valve shim replacement Austra12    Fuel:  95 Octane
6Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Mon Aug 14, 2017 9:09 am
50 bucks each out west thew. Of course k1100 are totally different to k100 in that the 11 looks like a bucket not a coin so expect rarer and more expensive.
7Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Mon Aug 14, 2017 12:58 pm
WoodyAUK75
WoodyAUK75
Aren't they 29mm, same as my KLX650? I recently re-shimmed it and was sure that was one of the things I learned when I started checking.
DOH! just read the bit about it being an 1100.
Last edited by WoodyAUK75 on Mon Aug 14, 2017 12:59 pm; edited 1 time in total (Reason for editing : Only read half the post.)
8Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Tue Aug 15, 2017 4:20 am
I think the Kawasaki shims have a chamfer. Not sure how that would affect their use in a K100.
K1100... didin't see that either. Cheers
9Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Tue Aug 15, 2017 4:41 am
The Kawasaki shims are square edged it's the early Yamaha from the 4cyl air cooled 1100 that has a chamfered edge.
10Back to top Go down   Valve shim replacement Empty Re: Valve shim replacement Tue Aug 15, 2017 12:53 pm
RicK G wrote:The Kawasaki shims are square edged it's the early Yamaha from the 4cyl air cooled 1100 that has a chamfered edge.
You forgot to add -... "and they're a complete bastard to get out" (dark memories of reshimming two K1100 Spectres about thirty years ago).
And I still have the bloody shim tool in the garage!!! Valve shim replacement 44271
