1 CLUTCH Sat Jun 26, 2010 12:45 pm
BIG D
Hi Folks,
Well I got into pulling the old girl apart, diff out splines in good condition having been re-greased before [good to know], then the swing arm and shaft again evidense of having been greased and all in good nick,
swing arm bearings ok [good job as I beleive they are not available from bearing merchants only BM].
So next I remove the gearbox to check the clutch, evidense of having the splines greased but I was going to have a look see the condition of the plate, the machine has done 45000 what I would like to know from any one who has done this before is how did you lock the engine prior to undoing the six bolts holding the clutch, I do not wish to be heavy handed and damage anything.
Then on the rebuild I can re-grease the shafts and splines with the Rocol 50% molybium I aquired.
BIG D
