1 Oil pump shaft dimension Fri Jul 07, 2017 10:31 am
aladin1
Can anyone tell me the length of the shaft on the later 19 tooth oil pump shaft (pre 01/1990) that has a bolt fix for the water section impeller. Mine is the earlier version with a nut to hold on the water pump impeller. Unfortunately when dismantling the pump the threaded section snapped. A replacement shaft is £138 (OMG) from MotoBins which is a lot of money to me. I would like to repair my broken shaft by converting it to a bolt fix version by removing the threaded section and drilling and tapping the shaft to accept a bolt. The shaft length on my nut fix shaft is 48mm from cog face to the end of the shaft not including the threaded section.
This is not my shaft it is a google image
