1 Repairing water-oil pump shaft Sun Feb 03, 2013 7:43 am
Domingo
Hi everybody,
I'm very surprised that, apparently no one has made this before or at least none has reported it. After searching in my Spanish site and also in this one, I haven't found any reference about this matter and this fact has driven me to make this post which I hope, will help you to fix the water-oil pump cheaper than before.
While repairing my 87 K100 water-oil pump I found that, the main shaft was completely corroded in its middle part so, it wouldn't be possible to reinstalling again without having same leaking caused by this.
I was totally resigned about buying a new one but then, after a deep degreasing, I realized that it wasn't made in just one piece, they were two. So that I took it and with a press I took it out the axel from the gear easily. The next step now is asking for a friend of mine to make a copy of this with a lathe. By my friend's own words, that's not gonna be a big deal to make a new one even the 6mm. allen socket in its widest end.
