101 Re: Making it my own Mon Apr 09, 2018 1:33 am
VinceD
Thanks robmack, I searched around the forums for some gauge disassembly-pics and found a topic by nitrogen 'fixing my instrument cluster'. There are some pics describing what is what but it isn't the same as what I have...
Could you help me out here? By rough shape comparison the 'bent' board would be the fuel-indicator part, but it was on the other side of the unit than the indicator light. The flat one was located there... furthermore there are some other pieces in there but they seem to be for the speed indicator since they are sandwiched between the indicator-plate and the indicator--mechanism.
If I could take a guess I would say that it's the bent one with bottom left the ground and positive and 'G'-labeled the input. Top right 'A' would be where I attach the led with the other end to ground. It's all guessing however...
