1 Bike still won't run when hot - what to check next? Tue Aug 08, 2017 9:51 am
timz10000
Thanks everyone who has given me help so far!
OK, my 1985 K100 won't run when hot.
I recently discovered my thermostat was bad (wouldn't open at all in heated water), so I just replaced it with a used one that does work (opens in heated water). Unfortunately, that didn't fix the problem.
It seems as though the engine is getting too hot (but my temperature warning light doesn't seem to work).
It runs fine for 10 or 15 minutes, then gets a little rough when hot and starts to stall unless I rev it high. At that point I shut it off so as not to damage anything, and when it cools down it runs OK again.
I've changed the Hall Sensors, air intakes, fuel lines, and swapped coils. (If relevant, the intake valves are a little tight.)
Any suggestions on what I should investigate next?
Perhaps the electronic temperature sensor a la this thread? https://www.k100-forum.com/t829-oh-dear-and-now-temp-issues-k100-rs
1985 K100
