1Back to top Go down   Fuel Tank woes... Empty Fuel Tank woes... Sun Jun 04, 2017 1:29 am
Kirkster
Kirkster
Ok,  Is this tank too far gone?  Seems like there are a lot of little issues that add up to No Bueno...
Fuel Tank woes... IMG_0424
Fuel Tank woes... IMG_0428
Fuel Tank woes... IMG_0427
Fuel Tank woes... IMG_0426
Fuel Tank woes... IMG_0429
Fuel Tank woes... IMG_0430
 I assume the fuel pump is also hosed...
2Back to top Go down   Fuel Tank woes... Empty Re: Fuel Tank woes... Sun Jun 04, 2017 2:25 am
Throw the pump at next doors cat as it is of no more use than a rock.  I had a tank that was near that bad repaired not long ago and it has come up really good. Use paint stripper to remove all the paint and examine it then as that will reveal any holes that are still hidden.
3Back to top Go down   Fuel Tank woes... Empty Re: Fuel Tank woes... Sun Jun 04, 2017 3:59 am
Whatever you do, USE GLOVES.
Or that black goo will be stuck to your fingers for days!
4Back to top Go down   Fuel Tank woes... Empty Re: Fuel Tank woes... Sun Jun 04, 2017 6:48 pm
Kirkster
Kirkster
duck wrote:Whatever you do, USE GLOVES.
About 15 hours too late on that tip.   (o)
I highly recommend "Worx natural hand cleaner". Took it right off.Fuel Tank woes... 314318
