Chinese master cylinder for $13.30 AU easy replacement. A guy from another site found these, a few variations on fitting them. You just need a 6mm to 8mm barb hose reducer, a new hose, a new brake pedal bolt with a recessed head do this with a Burr grinder electric drill or a lathe. I ended up moving the lock nut to the rear of the bolt so I could fit an aftermarket boot $4.00 Au.
Last edited by Two Wheels Better on Tue May 16, 2017 7:01 pm; edited 2 times in total (Reason for editing : Spelling error/clean up images)
I will be forever grateful to Martin for telling me about this master cylinder.  For the first time since I took it under my wing, my RT has a firm brake pedal.
It's amazing how easy it was to install this $7 master cylinder and how the results were so much better than what I got for the $200 I wasted on the OEM master cylinder.
Cheap and easy master cylinder replacement Instal10
It didn't take much longer than a rebuild to modify and install this master cylinder.  With the black paint it looks OEM.
One note: With the reservoir hose entering at the bottom of the master cylinder, some air is going to want to stay in the hose.  To make bleeding faster, I had to "milk" the air bubbles out by squeezing the hose until no more bubbles came up to the reservoir before pumping the pedal to bleed the system.
Last edited by Point-Seven-five on Mon May 15, 2017 12:33 am; edited 3 times in total (Reason for editing : added photo and additional text)
blacKbricK
blacKbricK
Could you share where you got the Master cylinder and Boot from Martin?
1987 K100RS VIN. 0143696K100 RSCJ ---- 1987 K100RT (Police) VIN 0095288 (Adopted from blaKey)  Plus 1998 R1100GS,   1980 Z1000ST, 1980 CB750,2005 Honda XL650V Transalp,1993 KLX650, 1998 DR250,1977 CR125 Elsinore and looking for more K bikes.( I'm hooked).
Source of M/Cyl is Ali heaps of them but you need the one with the slotted mounting holes shop around and you might even find a cheaper one. Look up universal or Honda Or Yamaha I paid $13.33 Au shipped to OZ. I also have one as a spare. https://www.aliexpress.com/item/Audew-Universal-Rear-Motorcycle-Dirt-Pit-Bike-Hydraulic-Master-Oil-Brake-Reservoir-Cylinder-Gold/32601326433.html?
The source of the boots is Glen a really nice helpful guy from Stainless Steel Sleeving Shop 22/193 South pine Rd Brendale Ph O7 3889 6669 boots are $4.00 Au. He also sleeves front M/Cyl's in stainless guaranteed and tested $200.00 Au. Once done replacement rubbers are $10.00 Au. And he will ship. Turn around on M/Cyl sleeving is approx 2 weeks.
He does not like doing rear M/Cyl on Bricks as invariably the plastic fitting that goes to the reservoir breaks and he has to make a new one out of brass with an "O" ring seal. A local brake place in Lawnton made up the brake hose on the spot $60-$70.00 I think. The 6mm- 8mm barb hose reducer I made on my ancient lathe but these can be had on Ebay. If you need any more information just ask.
Last edited by MartinW on Sun May 14, 2017 11:55 pm; edited 1 time in total (Reason for editing : left out address)
blacKbricK
blacKbricK
Thanks for that I will have a look. All the best. John.
Glen could also be a source for M/Cyl cup rubbers.
Last edited by Two Wheels Better on Tue May 16, 2017 6:56 pm; edited 2 times in total (Reason for editing : Redo pictures)
Thanks Martin that is good info for me and many others. BTW welcome to our Knuthaus
The first picture posted is the final version with the larger boot. In order to fit the boot I had to slot the end of the bolt and move the lock nut to the rear. In order to move the locknut to the rear a small amount of metal has to be ground off. The added benefit is that now all of the contact area between the M/Cyl and the brake adjuster bolt is fully covered.
Regards Martin
Is there anyone else not seeing Martin's photos?
By the way Martin +1 on what RickG said, another great example of the value of this forum with members around the world contributing ideas and information.
I can't see them
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
Chocolate
Chocolate
MartinW wrote:The first picture posted is the final version with the larger boot. In order to fit the boot I had to slot the end of the bolt and move the lock nut to the rear. In order to move the locknut to the rear a small amount of metal has to be ground off. The added benefit is that now all of the contact area between the M/Cyl and the brake adjuster bolt is fully covered.
Regards Martin
Hey Martin!
We can't see the pictures.
You have linked them to your Computer Hardisk but you have to upload them.
Maybe this link helps
https://www.k100-forum.com/t998-posting-pictures-and-movies
Thanks Laitch and Chocolate I am trying some may say very trying.Now all I have to find how to delete an image Cheap and easy master cylinder replacement 694830 Cheap and easy master cylinder replacement Boots_13
Cheap and easy master cylinder replacement Boots_12
Cheap and easy master cylinder replacement Chines22
Cheap and easy master cylinder replacement Chines23
Cheap and easy master cylinder replacement Chines19
Cheap and easy master cylinder replacement Chines21
Cheap and easy master cylinder replacement Chines20
Cheap and easy master cylinder replacement Chines24
Cheap and easy master cylinder replacement Chines25
Cheap and easy master cylinder replacement Chines26
Cheap and easy master cylinder replacement Chines27
Cheap and easy master cylinder replacement Chines28
Cheap and easy master cylinder replacement Boot_r11
Last edited by MartinW on Thu May 18, 2017 5:58 pm; edited 2 times in total (Reason for editing : Redo pictures)
roundel Now I can see the pictures, thanks.
If you go back in to edit your post, in the edit pane just put your cursor behind the photo you want to delete and backspace it out, then immediately hit the preview button and it will save your change, repeat as necessary. At least that is how I do it.
I need to use the preview button a lot before I send to tidy up my spelling and my tablet's auto correction.
Thanks fellas for the welcome glad to contribute, as a new member I might not be able to remove pictures. I  tried your method Gaz and I can't lock the cursor in behind. Maybe one of your nice forum facilitators will clean up my mess otherwise I'll wait until my daughter visits.
MartinW wrote:...as a new member I might not be able to remove pictures. Maybe one of your nice forum facilitators will clean up my mess...
Done.
PS, just click 'edit', when you see the empty box where the image should be, press 'backspace', repeat until ghost images are toast, then 'send' to save your work. What Gaz said.
Thanks TWB I've tried a couple of times when my daughter visits i''ll get her to have a look.
regards Martin.
