Go to page : Previous  1, 2, 3  Next
View previous topic View next topic Go down  Message [Page 2 of 3]
51Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 11:13 am
Danish biker
Chocolate wrote:Hello!
Wouldn't it be great to explain the subject in a way, so that the recipient understands it, WITHOUT getting angry ?!
SAG ?
Two people can look at that same picture, and they can have opposite views of what they're seeing. Keep this idea in mind when explaining a concept. Something that might be perfectly understandable to you might be incomprehensible to someone else.
Thanks Chocolate I need that
RAM suspension  - Page 2 112350
52Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 11:31 am
These help sometimes....................... Green beer
SAG is a measurement or dimension.
53Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 11:33 am
BobT
BobT
I am not getting angry.
A youtube video shows things in any language with the sound turned off.
There are also videos in just about every language in the world.
If I did not understand how to wire a plug then I would research, but I would not ask the question on a Japanese plug wiring forum without that additional research.
There is no need to know every technical term, but how can people answer if they don't know the question? If they do answer are you capable of understanding that answer?
If you go all the way back through this post I advised you to look up SAG on Google so that you had an understanding of what was needed when answers came, but you didn't bother.
54Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 11:39 am
Danish biker
Danish biker
Ok gentlemen I've used a couple of hours adjusting, measuring, riding.
I put the cable tie on the "rod" (please don't get angry anyone if it's supposed to be called something else  Very Happy  I'm sure most of you will know what I'm trying to say).
Did about ten up and down from central stand with me and my son on the bike. We even went "wrooom-wrooom" while sitting on the bike.
Eventually we ended up getting the tie to move exactly 3 cm. I made a note on my iPhone with picture etc  Laughing
The visible tread was 48,5 mm.
Then I did  the whole thing over with only me on the bike (still did the wroom-wroom each time). Very Happy
Surprisingly I ended up 12,5 mm lower. So visible tread was 36 mm. Took the bike out for same test drive as yesterday. I felt soft. Had left the tie on. When inspecting the tie it was moved fully up. This means the suspension had been worn out (or what ever the right word is).
So I'm defenetly not sticking with the 3 cm movement for solo ride. I'll go back to 2,5 which felt better. Any way thanks a million I got what I asked for which was a "factory setting / start out point"
Now for the sake of argument let's just say I stick with he 3 cm (1/3 movement) this would mean if I take my son to school which is a 15 km ride, I would have to turn the BLACK THING THAT ISN'T A SAG Very Happy 12 mm up and when dropping him off I would have to put the bike in the centerstand which I can't do without putting a brick under the back wheel, and then back the adjustment ring down 12 mm for my 15 km ride home. Seeems like a bad deal. The old original suspension needs absolutely no adjustment when I go from 1-up ride to 2 up ride.
In 30 minutes I'll take my son to town and the suspension is set for 2-up ride. I'll let you know what I think when I get back.
Oh by the way what the f is a SAG (in my country it is a case in court or a work case) Very Happy
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Sir Winston Churchill
55Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 1:19 pm
Danish biker
Danish biker
BobT wrote:I am not getting angry.
BobT aparently I've offended you. If not I might be doing it now.
There are no SAG or BMW K1100RS RAM 2 cm shorter YouTube videos in my language (not even if I turn the sound off).
lol!
Not in any other language either. Also I don't need to know what a SAG is. There is a damp adjustment and a spring adjustment. That's it.
If you could link to what ever YouTube video you think would solve my problem I'd be happy. But right now you are throwing smoke. The more smoke in this tread the more confused I get.
If I wanted to google or YouTube a solution to my missing adjustment abilities I wouldn't be on this site. I'm asking here to get advice to my problem, not to be guided to google or YouTube unless it is with a useful direct link.
So I got your advice regarding needing to google the word SAG and search on YouTube. My advice to you is if it gets obviously to you that you are not helping me, simply help by not commenting.
Thanks.
56Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 1:32 pm
Danish biker
Danish biker
Ok made the 2-up ride. The tie was about 1,5 cm from the top so no bottoming out (or what ever the proper words would be).
Back home riding solo everything felt ok so I see no point in adjusting back to a "2,5-3 cm tie movement".
Oh well eventually I'll probably give up and put the original suspension on and wear high heels.
58Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 3:16 pm
Danish I have four sets of boots with thick soles and two sets of lifts, a set of motorcycle road boots, a set of sneaker type Gortex hiking boots and for quick trips two sets of elastic sided work boots one with steel toe caps. With my seat cut down by 2" I can get away with out using the lifts in some boots.  For quick trips I just pull on the elastic sided work boots, and with the four pairs I can cover just about any occasion. The strange thing is nobody seems to notice that my height goes up and down. scratch RAM suspension  - Page 2 44271
59Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 3:20 pm
Corkboy
Corkboy
Danish biker wrote:Ok gentlemen I've used a couple of hours adjusting, measuring, riding.
That would be what I would expect to happen, i.e. the amount of visible thread would be less with just you than with the two of you.  Remember, the collar (i.e. the round ring) is compressing the spring before you get on the bike. So less compression is needed to support just your weight (and so less thread visible), than when you are supporting the weight of two people.
You have got it right, you just don't know it yet  Very Happy
Remember, the only thing that is supporting your weight is the spring.
Also, you mention adjusting for one or two people when you drop you son down to the shops etc. It is not an exact science, so don't worry about constantly adjusting it. i will take two people even when it is on the single person setting, if I am only doing it once, but if we are going for a weekend I will adjust it before I go. Similarly, if we are on our holidays, and I have to do a spin on my own, I will not adjust the setting just for that trip. The ride will feel a little hard, but it doesn't bother me.
A lot of other factors affect it, e.g. luggage, how bad the road is etc.
Now that you have the spring the way you like it, you can adjust the compression (the black knob) so that the spring doesn't bounce too much after a bump, but still allows the spring to bounce enough. That is a tougher job than the spring.
What I did was to set it at it's softest setting (don't know which way on the RAM, it may have H and S on the knob, meaning Hard and Soft, with corresponding arrows). Anyway, set it at the softest setting, go for a spin. You will notice the bike feels softer or bouncy.  Keep hardening the damping until you have gotten rid of the soft feeling. Again, it's more of a feeling than an exact amount.
The rebound damping does not change when you change from one to two people. The same amount of damping is needed regardless of how much the spring is preloaded.
(and as soon as I saw the picture of your shock with the "cable tie" on the inner rod, I knew you were on the right track).
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
60Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 4:10 pm
Danish biker
Danish biker
MartinW wrote:Danish I have four sets of boots with thick soles and two sets of lifts, a set of motorcycle road boots, a set of sneaker type Gortex hiking boots and for quick trips two sets of elastic sided work boots one with steel toe caps. With my seat cut down by 2" I can get away with out using the lifts in some boots.  For quick trips I just pull on the elastic sided work boots, and with the four pairs I can cover just about any occasion. The strange thing is nobody seems to notice that my height goes up and down. scratch RAM suspension  - Page 2 44271
Hi Martin have been searching for a lower seat but no luck.
61Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 4:17 pm
Danish biker
Danish biker
Corkboy wrote:(and as soon as I saw the picture of your shock with the "cable tie" on the inner rod, I knew you were on the right track).
Ha, ha when I woke up this morning I suddenly just new what the "bib" a cable tie was.
I'm going for a setting that will be a little on the "tight" side for a solo ride, since I often ride with my son.
Regarding the damping I surprisingly had to almost adjust it to its full adjustment. Maybe I just ride too many bad roads.
A million thanks RAM suspension  - Page 2 112350
62Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 5:03 pm
Just in case.  Too much rebound damping will make the suspension harder because it stops the suspension from returning to its normal length before hitting the next bump, so it gets progressively harder as the suspension cant 'unload'. (the term is called "packing down" but you don't need to know that.
'93 K1100LT
RAM suspension  - Page 2 K-dogs10
63Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 5:14 pm
Danish biker
Danish biker
Game on BobT RAM suspension  - Page 2 447221
http://www.motorcyclenews.com/new-rider/choosing-kit/2006/november/feb23-05-how-to-set-suspension-sag/
Relatively soon it says "the worst that can happen is you get completely confused" I did. Also it keeps referring to the owners manual. You probably didn't realize but my BMW manual doesn't include a shortened RAM.
http://racetech.com/articles/SuspensionAndSprings.
Started out positive when it was mentioned it wasn't rocket science. Well just until I once more had to lift up the front wheel from the ground. Have you read your links yourself? They are not helping me the least. Once more: "That is why I'm on this forum and not googling myself."
RAM suspension  - Page 2 Icon_biggrin
https://www.youtube.com/watch?v=
Ok I watched the YouTube without sound as you suggested. Relatively quick I could dertermin it wasn't a old K1100RS and it wasn't a RAM suspension. With out sound it made absolutly no sense at all. I turned on the sound and realized I need two people to lift my bike. No matter how many "YES-hats" I put on, the movie didn't help me one bit. I'm not sure if you realized:
1. I bought a suspension that is 2 cm shorter then the original.
2. I just need to know what way to turn in which order to get the damp and huge spring set right.
http://www.sportrider.com/ask-geek-set-your-static-sag
sag= L1-(L3+L2)/2 sorry I'm totally and fully lost. Still no RAM suspension and BMW.
http://www.motorcyclistonline.com/suspension-setup-101-part-i-setting-sag
Once more no RAM or K1100. And again I need both wheels off the ground.
http://www.motorcyclistonline.com/motorcycle-suspension-tech-tips-how-to-set-rider-sag-mc-garage
Once more it starts out with the front fork. Can't recall I ever asked about my front fork, which by the way isn't adjustable. The article continues in technical terms which almost made me fall asleep. No help what so ever.
Best of all is this one:
www.google.co.uk/?gws_rd=ssl#q=Set+up+motorcycle+sag
So this is the best one. You could have fooled me. 6 google links with more lifting the front wheel etc. Not even one BMW or RAM. I'm not sure what you where aiming for???
In one of the links pretty soon in the article a SAG-setting-guru is mentioned and he is quoted regarding it is difficult to set your SAG. NO S... Sherlock. I'm a infantry officer I just want to ride.
Any way thanks for your effort but sorry to say I could have done that myself, but once more just a lot of smoke.
64Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 5:18 pm
BobT
BobT
What a dick.
65Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 5:23 pm
Danish biker
Danish biker
BobT wrote:What a dick.
lol! lol! lol! lol!
Thanks mate and checkmate
66Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 6:43 pm
Danish I originally had my stock seat shaved and lowered by a upholsterer. At the moment I am in the process of shaving and lowering a spare seat. I have been given some really cool honeycomb foam by a friend in the US. The shaving and the lowering part is pretty easy just mark out and measure. Do a lot of marking and measuring. I cut it down and roughly shaped it with the wife's electric carving knife.  And used a 4" disc grinder with a worn flap wheel to shape and a foam medium grade sanding block to do the final shaping.Then either recover yourself with marine stretchable vinyl or get an upholsterer. There are a lot of sites out there to help here's the two I used.
https://www.youtube.com/watch?v=XZoq_D2kAZA
http://diymotorcycleseat.com/
Last edited by MartinW on Tue May 23, 2017 6:47 pm; edited 1 time in total (Reason for editing : Spelling error)
67Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 6:55 pm
Danish biker
Danish biker
MartinW wrote:Danish I originally had my stock seat shaved and lowered by a upholsterer. At the moment I am in the process of shaving and lowering a spare seat. I have been given some really cool honeycomb foam by a friend in the US. The shaving and the lowering part is pretty easy just mark out and measure. Do a lot of marking and measuring. I cut it down and roughly shaped it with the wife's electric carving knife.  And used a 4" disc grinder with a worn flap wheel to shape and a foam medium grade sanding block to do the final shaping.Then either recover yourself with marine stretchable vinyl or get an upholsterer. There are a lot of sites out there to help here's the two I used.
Nice video. He is doing a GREAT job but I'm not right there yet Very Happy
First i would need a extra seat so i wouldn't f... u. the original. Secondarely I would be concerned about the comfort when the seat is lowered.
68Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 8:23 pm
I am a motor trimmer by profession so I feel I can comment.
Lowering the seat can work yes.
The factory low seat is still better because the depth of the foam is greater as the base dips in between the frame rails instead of being flat like the standard seat (although the 1100RS seat base might go down the between the frame rails, the 1100LT certainly does).
A standard seat lowered too far especially if it's an older seat with tired foam padding can end up with you sitting on the base as the foam compresses under the rider weight. About as good as a cafe racer modification.  I have a comfort seat sitting on the shelf here at home that looks just fine but you end up sitting on the hard base after 30mins as the foam is too far gone. No need to lower it Smile
BTW Fork oil is adjustable in two ways: you can replace it with oil of a thicker/thinner viscosity and/or you can change the amount of oil also. Each of these things change different properties in the forks.  None of those properties being the height of the bike.
'93 K1100LT
69Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Tue May 23, 2017 9:21 pm
BobT wrote:The SAG is 2.5 cm you cannot screw the SAG! You do not seem to have looked at anything on the web or you would know what SAG is! 2.5cm is fine for SAG so you do not need to screw the spring compression screw anywhere.
Sag is an amount, a distance, not a device.
Why don't you stick a sock in it Bob your attitude is not at all helpful and totally unnecessary.
70Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 3:54 am
Chocolate
Chocolate
English[edit]. Alternative forms[edit]. stick a sock in it · stuff a sock in it. Etymology[edit]. Possibly from a crude means of muffling a gramophone's speaker. Verb[edit]. put a sock in it (third-person singular simple ...
Im learning english, great Forum ;-)
71Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 7:06 am
Danish biker
Danish biker
Ok gentlemen I hear you about the seat.
Before I bought the RAM I was desperately looking for a seat. The only real BMW bike shop in Denmark could order me a "comfort" seat but they couldn't tell if it was lower of even a "King and Queen" seat.
My present seat seems pretty low so I question that it can actually get lower but I'm all ears. If any one have a link for a RS lower seat it will be apreseated.
If I can get a lower seat the RAM comes off and the original suspension back on.
72Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 7:31 am
The low seat looks like this:
RAM suspension  - Page 2 K75RT%20modified%20Lee
I know this bike is a K75 and not a K1100RS but it doesn't matter, the same seat fits on a K75, a K100 or a K1100, RS or RT makes no difference.
The whole kit required includes: the seat, the black collar around the back of the tank, a new lock set, 2 hooks that screw to the rear bodywork, 3 stick on parts that go on the fuel tank to attach the black tank collar. Theres also a computer mounting box but you won't need that on an 1100, its only used on K75/100-2v
The comfort seat you are referring to you would probably call a king and queen, might be a little lower than standard but not much.
The low seat does come up for sale every now and again, you just need to keep looking.  No other way.
'93 K1100LT
73Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 8:36 am
I think this is the most entertaining and informative thread I've read here on rear suspension and height adjustment. It should be a 'sticky'. Very Happy
Rating: study must read
 RAM suspension  - Page 2 Austra12    Fuel:  95 Octane
74Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 10:16 am
Funny I was thinking exactly the same thing then I read Holister's post.
Very useful thread and explains a few very important things in practical terms.
Now I know how to adjust my sag. Damned if I can remember where I put it though.
75Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 11:08 am
I think you'll find you are sitting on it !  cheers
RAM suspension  - Page 2 Ir-log1188....May contain nuts!RAM suspension  - Page 2 Ir-log11
K75RTP - 1994
76Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 11:52 am
Now I remember. I put it with the lardons.
77Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 12:23 pm
Danish biker
Danish biker
Holister wrote:I think this is the most entertaining and informative thread I've read here on rear suspension and height adjustment. It should be a 'sticky'. Very Happy
And here I thought I was a total dick  Very Happy Very Happy  Sorry I know I'm pushing it. But yes there are some spot on direct pieces on information so even a none English speaking none techinal d... like me ends up getting the answers needed. I'm thinking I should have credit for keeping on asking and just not getting it.
lol!
Any way for future treads like this I would recommend you guys to use pictures more. One picture says more the words. A picture of a cable tie around the inner shining rod on the suspension would have made the intention clear with out any doubt. Just a suggestion to all you when dealing with guys like me. Not all bikers know or want to, take apart and put back together their bike.
I also finally know what the term SAG means. I could live a million years more and be happy not knowing, but now I know. So I adjusted the SAG again for soloride. The 1/3 SAG (3 cm) was just too soft for my liking. Also the suspension wore out. I went back to 2,5 cm and took excat same bouncy counrtyroad. Felt better and the tie was 1,5 cm from the top.
AL-58 if ever you find a seat you know will fit my RS, on eBay or similar please send me a link RAM suspension  - Page 2 112350
Right now I won't be thinking of SAG's or BMW's since I tomorrow will take my 16 old son to Ramstein concert RAM suspension  - Page 2 723598
How ever I of course have an additional question. Right now my brother in law is shortening the central stand. Either it will work or not. We will see, how ever my already shortened sidestand hits the extortion since it is too short to rest in he original rubber mount. I need some heat-safe tape or rubber I can put around the side stands leg. If you mention a brand etc. 99 % sure I won't be able to find it I need Denmark. If any one have anything suitable I'll gladly pay.
78Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 1:25 pm
Danish a low seat with all the bit's needed to fit it, but dear in my book. It did start out at $650.00 and these are getting thin on the ground in OZ. http://www.ebay.com.au/itm/BMW-factory-low-seat-for-k75-k100-k1100-/182452624994?
79Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 1:57 pm
Danish biker
Danish biker
MartinW wrote:Danish a low seat with all the bit's needed to fit it, but dear in my book. It did start out at $650.00 and these are getting thin on the ground in OZ. http://www.ebay.com.au/itm/BMW-factory-low-seat-for-k75-k100-k1100-/182452624994?
Hmmmh wonder how much shipment will be Rolling Eyes
Long way from Down Under to up North. But thanks it looks pretty cool.
80Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 2:20 pm
www.motorworks.co.uk or www.motobins.co.uk or www.jamessherlock.co.uk will have them from time to time and are well known on the forum as being reliable to deal with.
Also, a few of us are heading down to France in September for a camping trip.
This would be a good run to check out your new set up and compare your sag with others. An excellent camp site down at St Leon sur Vezere where we have previously based ourselves surrounded by some rather nice bike roads and eating places.
81Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 2:20 pm
Yeah - all apart from the unnecessary slanging match.
(A slanging match is an angry quarrel in which people insult each other.)
Having offered my suggestions at the start of the post (I really don't mind if forum members disregard my comments if they don't find them helpful or, if I am technically wrong, if someone politely corrects me - and thereby educating us all), I disengaged because I didn't enjoy reading the way the thread was developing. I do enjoy posts containing humour and healthy banter, but sometimes lines are crossed and it all goes a bit sour and distasteful.
Sharing, learning and keeping things respectful is the firm foundation that this fantastic forum is built on. Please, let's keep it that way!
RAM suspension  - Page 2 Uk-log10 RAM suspension  - Page 2 Sco-lo15
                              Paul  RAM suspension  - Page 2 905546712
82Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 2:24 pm
Leprachaun Very drunk Very drunk Very drunk Very drunk Very drunk Very drunk Very drunk drinking-wine
83Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 2:34 pm
Danish biker
Danish biker
92KK 84WW Olaf wrote:www.motorworks.co.uk or www.motobins.co.uk or www.jamessherlock.co.uk will have them from time to time and are well known on the forum as being reliable to deal with.
When I got to the "eating" you had me Very Happy
84Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 5:28 pm
Well, maybe you might make it down!!! I have my ferry booked for 2nd September.
85Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Wed May 24, 2017 9:26 pm
Now $450 Buy it Now?
The last one I bought I was very lucky as the didnt know what he had and advertised it as a low seat for an R75.  No bids bar mine.
I've always liked the low seat on the sidecar as the reduced CofG by lowering my weight improves the handling noticably.
'93 K1100LT
86Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Thu May 25, 2017 8:44 am
Totally agree with that Paul. I was impressed with the good humoured way in which Danish responded.
rendeer
PS. we would call it 'a slagging' here in Oz.... it was a little one sided.
87Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 11:36 am
Danish biker
Danish biker
Humor is always a good way to avoid a pissing contest how ever I'm sure I did my part in getting the tread sidetracked. Sorry for that.
Any thoughts on what I can put around the part of the leg of my now shortened side stand that can take the heat from the exhaust? I don't want the metal from the side stand against the exhaust (it also makes an anoying "Klonk" sound everytime I put the sidestand up).
88Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 12:28 pm
K-bikes have a rubber, heat resistant bumper to prevent metal to metal noise. Attached is a K1100 exhaust diagram with the part circled.
RAM suspension  - Page 2 Stand_10
89Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 12:43 pm
Danish biker
Danish biker
He, he sorry I'm teasing you now. RAM suspension  - Page 2 112350
My side stand is shortened so it won't reach the original rubber bumper. What is now touching the exhaust is the middle of the leg of the side stand. So I need some tape or rubber to put around the leg.
You know: The RAM is almost an inch shorter so the side stand is now also at least an inch shorter (original length will tilt the bike).
90Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 12:47 pm
Get out your bayonet, cut down the bumper and tape it to the leg. Laughing
91Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 1:14 pm
Danish biker
Danish biker
Laitch wrote:Get out your bayonet, cut down the bumper and tape it to the leg. Laughing
Never gonna happen. I still have a unshortened leg and if/when I decide the RAM is just not worth it (maybe when I get a lower seat) I need the bumper as original as possible since the original suspension will go back on. Also it catches the central stand from its present position. So can't be moved.
Come up with a better solution Very Happy
92Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 1:23 pm
Apply for a grant from Aarhus Universitets Forskningsfond or submit it to them for their consideration. They might come up with something. You might come to enjoy its rhythmic knocking if you just leave it as it is, plus it will warn people of your whereabouts. Very Happy
93Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 2:05 pm
On the other hand, you could get a short length of silicone hose to cover the leg.  I recommend the silicone because rubber hose may or may not be able to withstand the heat from the exhaust.
Cut it lengthwise, slip it over the leg and tie it with some wire.
94Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 4:05 pm
Danish biker
Danish biker
Hmmmm silicone hose. I'll have to google that and see what comes up in Danish. But it is suggestions like that I'm searching for.
95Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 4:10 pm
Danish biker
Danish biker
Laitch wrote:Apply for a grant from Aarhus Universitets Forskningsfond or submit it to them for their consideration. They might come up with something. You might come to enjoy its rhythmic knocking if you just leave it as it is, plus it will warn people of your whereabouts. Very Happy
Ha, ha drove by Aarhus University today. Should have stopped and asked.
I guess I'll have to go by the general automechanic and ask him. I was just hoping for a link like:
The-super-heat-resistance-duck-tape-also-sold-in-Denmark-online-here-just-click-on-this-link
lol!
96Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Fri May 26, 2017 6:11 pm
Danish biker wrote:I was just hoping for a link like:
Silicone tubing seems like it might work. Check with the Logistics support centre. If they buy in bulk, maybe they'll get the NATO discount and you can get a few pieces from them. Check with your contacts. Laughing
97Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Sat May 27, 2017 6:20 am
Danish biker
Danish biker
If you could give me an excampel so where silicone tubing is used in general I might have a chance. If I know what industries etc. uses these tubing I would know where to ask and what to look for.
98Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Sat May 27, 2017 8:53 am
99Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Sat May 27, 2017 9:00 am
Silicone heater hose is used on some cars.  I get mine at an auto parts supply.
100Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Sat May 27, 2017 9:52 am
If that doesn't work you can get silicone bake ware and cook ware too. Its also rather heat resistant and comes in various colours....
101Back to top Go down   RAM suspension  - Page 2 Empty Re: RAM suspension Sat May 27, 2017 9:59 am
92KK 84WW Olaf wrote:If that doesn't work you can get silicone bake ware and cook ware too. Its also rather heat resistant and comes in various colours....
RAM suspension  - Page 2 Screen10
View previous topic View next topic Back to top  Message [Page 2 of 3]
