1Back to top Go down   Wire to headlight socket color? Empty Wire to headlight socket color? Thu May 18, 2017 2:58 am
nino
I am a little bit lost in connecting new H 4 socket. I have to connect it properly but after cut od wires I am confused: Which wire goes to left side of socket, which goes up in the middle, which goes to to right, looking from behind. Instalation is from early K 100. Three wires: grey green, black red, grey red
Thanks in advance
2Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Thu May 18, 2017 3:41 am
nino wrote:Three wires: grey green, black red, grey red
Thanks in advance
These colours is not OEM, and not after the DIN standard which is used.
3Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Thu May 18, 2017 3:49 am
nino wrote: Which wire goes to left side of socket, which goes up in the middle, which goes to to right, looking from behind.
Left: Brown...ground, middle: yellow...low beam, right: white...high beam.
4Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Thu May 18, 2017 3:50 am
Have relays been fitted Nino that may explain the different colours.
The wires should be Brown for earth/ground  White for Hi Beam and Yellow for Lo beam.
5Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Thu May 18, 2017 4:43 am
nino
Thanks problem solved. I am not aware of any headlight relay on bike. if there is one must be in relay box.
6Back to top Go down   Wire to headlight socket color? Empty Not shure still Thu May 18, 2017 5:32 am
nino
Still not shure
On the new socket i have red wire left, yellow wire center up and blue wire right which I have to connect
with grey green, black red, grey red
7Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Fri May 19, 2017 7:37 am
You will need a voltmeter/multimeter or alternatively, a 12 volt bulb in a socket with two flying leads.
Look at the back of the new socket: the red wire is earth (!!!), the yellow wire is dip beam and the blue wire is high beam.
With a voltmeter, on the bike:-
1. Turn the lights on to dip beam
2. Check for voltage on all three wires. Whichever colour has 12 volts on it is the dip beam - connect to the yellow wire on the socket
3. Turn on high beam. Again, check for 12 volts. Whichever colour has 12 volts on it is the high beam - connect to the blue wire on the socket
4. The 'other' wire is earth - connect it to the red wire on the socket.
If you only have a bulb for a tester, do the same as above but earth one side of the bulb to the bike. If the bulb lights, you have 12 volts on that wire.
8Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Fri May 19, 2017 12:29 pm
Here is a typical H4 socket:
Wire to headlight socket color? H4PLUG
Wire to headlight socket color? Frog15Wire to headlight socket color? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   Wire to headlight socket color? Empty Re: Wire to headlight socket color? Fri May 19, 2017 1:01 pm
nino
Thanks, problem solved. With new voltage regulator H 4 looks brighter
