1Back to top Go down   charging socket Empty charging socket Mon Jan 07, 2013 3:37 pm
ali2908
ali2908
I have decided to do a 2000 mile tour this summer so I am starting to prepare the bike for it's first long distance tour (mine as well). I need to fit a power outlet to run a Satnav and charge my phone as well, what do I need to do. Do I wire a direct feed to a cigarette outlet (fused accordingly ) or is there an accessory outlet in the fuse board to use?
I think this will be the first of many questions over the next few months as I prepare for the journey.
Ali
1985 K100 RS
Regards
Ali
1985 K100RS
2002 K1200 RS
2Back to top Go down   charging socket Empty Re: charging socket Mon Jan 07, 2013 5:49 pm
twincarb
twincarb
Hi Ali,
In the relay box just under the tank there is an auxiliary wiring socket which is white which is used to plug the OEM additional harness in if I recall correctly... you could take a feed off of that. Have you got the Aux power which is located on the left hand side of the bike connected to the top cover over the ignition coils?
That could be another option to take a feed off of that If both of the devices are USB fed you can get a Cigarette lighter to double USB power convertors similar to this I have never used one myself mind...
Yamaha Thundercat
charging socket 169042charging socket 169034
3Back to top Go down   charging socket Empty Re: charging socket Mon Jan 07, 2013 5:52 pm
ali2908
ali2908
I have not checked will try and look tomorrow, unfortunately the bike is stored in an unlit container at work.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
4Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 6:34 am
I did exactly what is mentioned above...although I installed a waterproof cig lighter attachment to which I added a dual USB with a water cover thingy.....works a treat.
http://www.ebay.com.au/itm/110966193186?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
charging socket Waterp10
KKlompy charging socket 2854237993
charging socket Au-log10
5Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 11:26 am
These folk are the industry standard for motorsport-sized powered sockets, extension leads and plugs. They offer a myriad of different ways to power your farkles like GPS, MP3, radar detector, mobile phone & etc. They replicate and add to BMW's longtime 'Hella" socket which should or might be just on top of your ignition coils. IMO this is the cleanest way to go without the size of a cigarette lighter socket. I've converted all of my motorbike-used accessories to this type of fused, weather-protected plug and socket. They're great as a portal for charging your battery too.
Try this link:
http://www.powerlet.com/shop-by-product/plugs-sockets-wire-more/PWRDIST
charging socket Powerl10
...and this link too:
http://realoem.com/bmw/showparts.do?model=0503&mospid=51751&btnr=61_0240&hg=61&fg=34
6Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 2:47 pm
I recall when I bought a couple of plugs from the local dealer there were two options the cheaper one was made by Hella and came in a Hella packet and the other was a genuine BMW spare but more expensive. I wanted two so I bought one of each, I wish now I had not bought the Hella the quality of construction and the cable strain relief was nowhere near as good as on the BMW one. You gets what you pays for I suppose.
7Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 3:11 pm
ali2908
ali2908
I have looked at my bike today and there is nothing fitted on the coil cover (see picture) Moto-bins and motorworks have the aux kit probably just get that.
charging socket Coil10
Thanks again
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
8Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 6:42 pm
Klompy the grey brick wrote:I did exactly what is mentioned above...although I installed a waterproof cig lighter attachment to which I added a dual USB with a water cover thingy.....works a treat.
where did you mount it Klompy? got a pic of the usb installation?
charging socket Ir-log1188....May contain nuts!charging socket Ir-log11
K75RTP - 1994
9Back to top Go down   charging socket Empty Re: charging socket Tue Jan 08, 2013 7:00 pm
ali2908
ali2908
Having looked on the American ebay site some of these look like they would be suitable to mount up in the dashboard area
http://stores.ebay.co.uk/12vtechnology/Sockets-with-Mounts-/_i.html?_fsub=2636558010
I may order one of them and let you know how it goes.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
10Back to top Go down   charging socket Empty Re: charging socket Wed Jan 09, 2013 2:29 am
11Back to top Go down   charging socket Empty Re: charging socket Wed Jan 09, 2013 3:49 pm
This is where I mounted mine.
charging socket Sam_0412
12Back to top Go down   charging socket Empty Re: charging socket Wed Jan 09, 2013 5:09 pm
Ali, I've just seen this on e-bay.
http://www.ebay.co.uk/itm/BMW-K-100-RS-1989-RIGHT-FAIRING-INFILL-/140891875038?pt=UK_Motorcycle_Parts&hash=item20cdcf66de
An infill panel to which someone has fitted a BMW type socket, looks neat.
13Back to top Go down   charging socket Empty Re: charging socket Thu Jan 10, 2013 6:16 am
got a bloody big temp gauge there myself.....looks tidy though and inexpensive
charging socket Sany0222
charging socket Sany0223
14Back to top Go down   charging socket Empty Re: charging socket Fri Jan 11, 2013 5:42 pm
ali2908
ali2908
Thanks guys you've given me lots of ideas, I have ordered a kit from Motor-works hopefully arriving tomorrow.
Regards
Ali
1985 K100RS
2002 K1200 RS
