1 Centre/side stand problem Mon May 15, 2017 7:58 am
Simplemind
I need to replace the side stand bush on my 88 k100LT. Is the bolt/pivot a threaded bolt ?. I've had it soaking in wd40 over night but cant shift it. I was going to replace the entire centre stand but the po had obviously had a go and rounded off the hex bolts. I had thought of just cutting through the bolts and using a stud extractor to remove the remains of the bolts. The centre stand looks to be in reasonable condition for its age just the side stand that's loose.
