1Back to top Go down   Oil Filter removal tools Empty Oil Filter removal tools Mon Jul 25, 2016 7:40 am
Rickmeister
Rickmeister
All, There has been much written about oil filter removal from the engine of a K Bike. Because of the relatively small orifice to access the filter, the "socket" type tool is required. Also, RickG has put out a list of compatible oil filters. They are undoubtably all different sizes re: tool size required.
So, the other day I bit the bullet, rummaged around Fleabay, and lashed out and bought a kit of said socket thingos (21 off!!). My choice of filter these days is the Valvoline V022, which has 14 flats and measures 72mm AF (Across the Flats) I've had great difficulty in obtaining the correct "socket", hence this purchase.
So, FYI, I measured each of the 21 "socket" doo-dads, as this information wasn't available on the Fleabay site.
In the Kit: (The numbers are kit reference numbers)
901    (14 flats)       64mm AF
902    (14 flats)       67mm AF
903    (14 flats)       74.5mm AF
903-1 (15 flats)       75mm          between a flat and its opposite corner.
903-2 (8 flats)         74.2mm AF
903-3 (15 flats)       74 mm               "  "
903-4 (14 flats)       72.5 AF   (This one fits the Valvoline filter, but still a bit "sloppy").
903-6 (12 "dimples") O/A ID 76mm.
904    (15 flats)       78mm between a flat and its opposite corner.
905    (15 raised parts of a circle?) 75mm ID, 72mm across "dimples".
905-1 (14 very flat flats!) 74mm AF.
906    (18 "dimples")  86mm across "dimple" hi-spots.
907    (15 flats)        88mm between flat and its opposite corner.
908    (15 flats)        91mm     "             "           "
909    (15 flats)        92mm     "             "           "
910    (15 flats)        93mm     "             "           "
911    (12 dimples)    O/A ID 80mm, hi-spot to opposite hi-spot  77mm.
911-1 (15 very flat flats!)  79mm between flat and its opposite corner.
914    (15 flats)               101mm   "           "          "
915    (15 flats)                 92mm   "           "          "
918    (15 flats)                 73mm   "           "          "
Maybe this info will be useful to somebody out there.
(BTW..saw a beaut looking K1, blue with yellow lettering, on Melbourne St this afternoon, heading towards Maitland!)
Cheers, Rickmeister.
911-1 (15 very flat flats)  79mm between flat and its opposite corner.
2Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Mon Jul 25, 2016 8:33 am
OK Rickmeister, which size fits you?
3Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Mon Jul 25, 2016 8:34 am
Rickmeister,
I am just blown away by your dedication to the forum .................. Oil Filter removal tools 112350
4Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Mon Jul 25, 2016 12:04 pm
[reads the list and scratches head] I think I got lucky. Whatever filter I use (comes from Motorworks), it uses the same size tool as the filters on my Moto Guzzis.
5Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Tue Jul 26, 2016 12:27 am
Rockman
I'm still using the one I bought for my first K back in 1987 (83 standard K100). Still seems to fit every time. I must be lucky too.
6Back to top Go down   Oil Filter removal tools Empty Oil Filter removal tools Tue Jul 26, 2016 1:06 am
Ulli, you have done well. I reckon in that assortment, there must be an oil filter removal tool for every oil filter on the market. I'll measure the Ryco 418 filter and see if you have one that fits. Maybe your user name should be "Oil Filter Tool"
7Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Tue Jul 26, 2016 4:45 am
"Maybe your user name should be "Oil Filter Tool"
...then, being Aussies, we'll shorten it to "Tool" Laughing  Shocked Laughing
8Back to top Go down   Oil Filter removal tools Empty Photo... Fri Aug 19, 2016 3:05 am
StephenAcworth
StephenAcworth
Can you share a photo for all us tool fetishists out here???
9Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 10:53 am
JGT
JGT
What are the advantages of using other make filters? Is it just cost? I don't stick slavishly to original manufactures products but o/e filters are readily available and alternatives are something I have never given much thought too. John
1992 K75
10Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 11:14 am
StephenAcworth wrote:Can you share a photo for all us tool fetishists out here???
Sad, very sad   Evil or Very Mad  There are places for people like this.
11Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 11:58 am
Hi guys I use the RYCO 418 filters and use the standard BMW tool..nice snug fit...
:O) KKlompy
KKlompy Oil Filter removal tools 2854237993
Oil Filter removal tools Au-log10
12Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 3:20 pm
StephenAcworth
StephenAcworth
Ha!!! I know and I'm in one... 6 month winters full of ice and snow...  Laughing
13Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 3:37 pm
k100virgin wrote:What are the advantages of using other make filters? Is it just cost? I don't stick slavishly to original manufactures products but o/e filters are readily available and alternatives are something I have never given much thought too. John
Yes, cost. I use Bosch 52161 filters on all of my Ks. Same size as the OEM one.
In the US at least, a good cheap oil filter wrench is the OEM brand Type B (part # 25401) which can be purchased from Auto Zone and other parts stores.
On K bikes I've purchased where a prior owner used to much torque and the filter wrench slipped, pounding on an oil filter wrench with a rag or some steel wool in it has made loosening "stuck" filters easier than taking off the sump plate to pound a screwdriver through it.
14Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 3:43 pm
StephenAcworth
StephenAcworth
Oil Filter removal tools ImageSo I'm guessing something like this? I never knew they existed and was using an adjustable strap...
15Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Fri Aug 19, 2016 4:02 pm
What you saying Dave? I thought this was the place for people like  that us!!
PS I have just invested in a 16 piece blind hole bearing removal tool kit (including slide hammer) to help do those pesky wheel, steering head etc. bearings. Don't know how good the quality is yet, but raring to try it out, but best I buy some new bearings first.
Thanks for the detail Rickmeister, not something I need right now, but that is the beauty of this 'ere forum...when you find you have the need, you can go find the knuggets of knowledge
Oil Filter removal tools Uk-log10 Oil Filter removal tools Sco-lo15
                              Paul  Oil Filter removal tools 905546712
16Back to top Go down   Oil Filter removal tools Empty Re: Oil Filter removal tools Sat Aug 20, 2016 1:06 am
It is indeed.  A very big welKome Stephen.
 Oil Filter removal tools 44271
17Back to top Go down   Oil Filter removal tools Empty OIL FILTER REMOVAL TOOLS Mon May 15, 2017 5:57 am
redrockmania
redrockmania
Word of caution about oil filter fitting and removal. My 1983 K100 is ex-Japan and the oil filter at last change in Japan prior to me getting it must have been (over)tightened by a Sumo wrestler. I broke a filter removal tool (correct size for the filter) and only got the filter off by driving a 10mm diameter high tensile bolt through it and then putting a 600ml long steel pipe over the bolt shaft and swinging on it with significant force. It eventually broke free, but I had to exert so much force I was fearful I was going to crack the engine casting. Lesson: do not over tighten.
