1 Rattle at Idle Sun Apr 02, 2017 12:13 pm
Kafflut
2V K100 1986
The engine runs nicely at higher revs, but with the throttle closed it makes this rattle noise.
Before I start looking around in there I read up in Haynes and Clymer. I read that this kind of noise could be because of excessive cam shaft end float/cam shaft thrust bearing beyond wear limit. My concern is, when I open it I'm going to check cam shaft end float. The remedy according to the manuals is "replace the cam shaft"
Why? Is a thrust bearing not a wear part?
I'm hoping that I'll need only to replace the the chain guides, but I may as well check all other stuff for wear while I have the engine open.
