51 how to? Thu Apr 27, 2017 2:52 am
SniperX
Is there a guide or a how to here on this site or anywhere for this? Preferably a video? This is next for me after I finish the new fan and installing the trunk.
Go to page : 1, 2
I suggest ask Albyalbatross1, RickG & Crazy Frog. I also found this pdf in German that could be helpful http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/output_shaft_repair.pdfAlbyalbatross1 wrote:I agree with rick. A lot of work in there for the repair...It is a solid repair. The hard part is milling the hardend steel..
I pulled down the repaired output shaft today for a look see.
here are the nuts used. Very little machining to be done. just enough for the nuts.
And when i showed a friend of mine for a third eye.. he simply said.."HUH! There just threaded rivets..!! get some more the same diameter and a bit longer and thread em bolt em up!!""Albyalbatross1 wrote:I agree with rick. A lot of work in there for the repair...It is a solid repair. The hard part is milling the hardend steel..
Who new it would be that simple...Now who do we know with a mini lathe to mill out a bit of alloy and hold a rivet in the chuck to thread it??? This repair should last .
Go to page : 1, 2
Similar topics
