1 Idle Woes! Wed Apr 26, 2017 10:57 am
rob_gordon
I have a 1989 K100RT that has done 60000 miles. I acquired it in January 2016 when it had done only 46000 miles (5 years sitting in a garage unused!). It ran well for about 10,000 miles then started to develop an issue at start up. It would need the 'choke lever' on for a good 10-15 mins of running but once warm would run great. I have replaced the fuel filter, fuel pump seal (old on was perished to bits) and all fuel pipes in the tank and outside. I also replaced the slit crank case breather tube and the coolant temperature sensor but the problem persists. in fact it is much worse now as although the engine starts straight off, after about 15 seconds, the idle drops off even with the 'choke lever' on full and the bike runs really rough with clunking noises from the engine. If I give it some gas and hold at about 1500-2000 rpm, it runs ok but if I try to set off before its warmed up then I have very little power. Once warmed up, the bike runs fine accept some times when i drop the throttle back to stop at a red light for example, the bike will cut out. At other times it idles fine at 1000 rpm.
My plan was to inspect and clean the injectors and the throttle bodies and all air intakes but wondered how easy it was to do this. Also thought about checking the coils. Again, not sure how to do this so if anyone has any advice, I'd be very grateful. Also, if anyone can think of any potential quick wins before i start digging into the guts, that would be even better.
