1 Air filter change made easy? Mon Apr 17, 2017 2:09 pm
SniperX
Air filter change made easy? How do you change the air filter on an 80s k100rt without wanting to throw stuff long distances?
Laitch wrote:Is it the removal of fairing sections that's disturbing you or is it compulsion control in general that's the challenge. The replacement itself is straightforward.
Bloody hell mate! I almost had it! I was thinking the top of the airbox had to come off but almost had the filter out when I gave up and asked! THANKS!
Last edited by KJustin on Mon Apr 17, 2017 6:08 pm; edited 1 time in total (Reason for editing : fixed typos)
1986 k75, 1985 K100rt, |
If it were that much lower it would been only two minutes of my life instead of three minutes that I'd have lost every time I replaced that filter. O, the things I could have done with that extra time; the regrets I would not have.
I think that's what happened with mine! Tremendous PITA!indian036 wrote:Or in my case, Air filter change made hard! The previous owner had somehow put it in backwards, with the higher lip that should have been on the right instead being on the left.
Dai wrote:
CF: replacing the MAF is easy-peasy. You just need to hack through the cable on the left-hand side just in front of the airbox and fit a four-pin connector in there.
Mine too, took me ages the first time!KJustin wrote:I think that's what happened with mine! Tremendous PITA!indian036 wrote:Or in my case, Air filter change made hard! The previous owner had somehow put it in backwards, with the higher lip that should have been on the right instead being on the left.
I'm sure most see that after the new K bike Olympic sport known as "Spanner Throw".....Dai wrote:Notwithstanding the word 'front' molded into one lip...
Inge K. wrote:Dai wrote:Notwithstanding the word 'front' molded into one lip...
Nah, but close...............
But on the other hand it would have helped some, with "front" on the other end....
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Air filter change made easy?
Similar topics
