SniperX
SniperX
I am finally changing my spark plugs next week. The stock Bosch is incredibly hard to find locally so I'd love to get an NGK or something I can get locally. If the stock Bosch is the best to go with what number do you use?> I forgot what is in mine when I had it apart last year for the timing chain...I also remember getting a set of NGK (which I still have) for it and found out they no longer come with the tops and the tops are scarce as hens teeth so those are out. BTW the NGK I got is the D7EA but has no ferrule or whatever you call that screw on tip for the threaded end of the plug. Anyone know where to source a set of those tips or ferrules or what the hell they are called? I'd buy a case of 10 if needed. I use to throw them away!
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
SniperX wrote: Anyone know where to source a set of those tips or ferrules or what the hell they are called?
Terminal nuts. Trade them for cigarettes, walnuts or whichever medium of exchange local mechanics are using.
Sniper,
If you have no luck locally for the ferrules, send me PM and I will post some out for you.
I raided a good friends car workshop a couple of years ago and he said, "The orphan spark plugs box is over there.  Take all you need."  So I did..... I took them all.  We are still friends.
If you have a look at the euromotoelectrics website in the US they have Bosch plugs there.  The Bosch plugs are getting harder to find in Oz whereas the NGK are readily available.  Bosch X5DC or NGK D7EA for me.
Dave.
Last edited by TacKler on Wed Apr 19, 2017 9:35 am; edited 1 time in total (Reason for editing : EME reference)
Snod Blatter
Snod Blatter
Just as a little FYI if you look up the K100 on NGK's website they recommend the D8EA plug instead. If your engine still has the original Bosch plugs please do compare the length of them to whatever you're replacing them with - I have fitted D7EAs but the old Boschs looked a little longer to me.
Also, in other bikes I have tried copper NGK, copper Denso, Iridium Denso and Champion (for a laugh). Nothing lasts half as long or is as well behaved as the normal boring copper NGK plug.
Oh and I've been calling them nipples.. Laughing
Bosch X5DC in the cardboard packet, they are made in europe, not the blister pack as they are made in Brazil and wont last well or NGK D7EA
Quite a few places here also go for the D8EA in the Ks, including some BMW experts. Not sure of the physical differences but from 2 stroke days I have a feeling that the difference between a D7EA and a D8EA will be the running temperature, the 7 being hotter than the 8. I have used both and also the Bosch and also Champion and can't say there is a very obvious difference. Apart from the fact that with the NGKs a few times I have had plugs fail after a few hundred miles.
Thanks to BAE there is a box of D7EAs in my shed......
D7EAs. Dunno what Olaf is up to but I've not had an NGK fail yet in any bike and I've run some for six or seven years at an average of 15K miles a year before remembering to change them. I have noticed that the K is sensitive to the gap; BMW state a gap of 23thou but as the nearest feeler gauge I have is 25thou... Once it wanders passed about 4thou too wide (IME) the engine starts to protest on warmup.
BobT
BobT
BMWs were built metric and therefore the plug gap should be 0.6mm (+0.1/-0.0) with a maximum wear limit of 0.9mm. Measure in thou if you want but you speedo will not measure furlongs so make life easy and buy a set of feeler gauges that are metric (£5 or less).
BobT wrote:BMWs were built metric and therefore the plug gap should be 0.6mm (+0.1/-0.0) with a maximum wear limit of 0.9mm. Measure in thou if you want but you speedo will not measure furlongs so make life easy and buy a set of feeler gauges that are metric (£5 or less).
Uh-oh, beside gapping my spark plugs in thousandths I have been buying oil for my BMW's in non-metric gallon jugs.  Am I unwittingly damaging my engines???
Nuthin wurse than buyin oil by the gallun it'll wreck the injun.
Not up to now but them imperial long chain molecule holder jugs are no longer compatible with them metric long chain molecules.
RicK G wrote:Nuthin wurse than buyin oil by the gallun it'll wreck the injun.
Oh no!!!!!   My bricks are doomed!!!  affraid
Just don't buy it from a cowboy and you injun will be ok.
Last set of bosh X5DC that I bout on the Internet are made in ..... India.
I will try them after I replace the injectors.
Spark plugs...what do you swear by?  Frog15Spark plugs...what do you swear by?  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
And I'll bet they are those undersized US gallons not the full sized Imperial gallon.
'93 K1100LT
Spark plugs...what do you swear by?  K-dogs10
Yeah if you use those undersize galluns of gas then you'll be runnin lean.
Oh Dear, Imperial Gallons bigger than American ones Imperial long chain molecules longer then Metric ones, a shift from metric gaps to imperial gaps to create a greater search area for that explodable stuff in the combustion chamber, we are so lucky we have a under square engine as I cant imagine how hard it would be to ignite anything in there if it was over square. I truly hope none of you have round gas cans for these square engines and all these chains of molecules on a shaftie at that. Where will it all end. Whose Bosch will we trust. Where do we buy spare sparks for our X5DC's or AC's for that matter, we need a rectifier for the cause. Blister packs like all blisters aren't welcome, but put them in a cardboard carton and I'll buy them by the boxful. Before I am kicked up the D7EA I'll finish this post. Laughing
