1Back to top Go down   squeaking pads K100RS '87 Empty squeaking pads K100RS '87 Mon Jun 14, 2010 10:19 am
LifeGuard
LifeGuard
Hi
Is this normal that brand new FERODO brake pads are squeaking?
I cleaned rear brakes and they also start squeaking.
http://tchorzewski.net
2Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 3:43 pm
Vudis
Here in Lithuania, at the car parts' shops we have a special membrane, which could be cut into pieces and you glue it to the other side of pads. They cost something like 3 USD per 10 sq cm. So, it's a cheap way to stop those pads squeaking Smile
And it reaaaaaaaaaaalllly works.
3Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 4:34 pm
They have all kind of stuff to stop the squeaking. They also have also some sort of paste that you put between the piston and the pad.
The goal is to absorb the vibration without decreasing the pressure on the pad.
squeaking pads K100RS '87 Frog15squeaking pads K100RS '87 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 5:02 pm
LifeGuard
LifeGuard
Thanks guys you guide me. I googled and found solution:
squeaking pads K100RS '87 31821316
I have to go to Mercedes Service and ask for this paste. It costs 1,2 Euro
5Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 5:05 pm
I believe that the membrane would be a better solution as the pistons are hollow on the side of the pad.
6Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 6:59 pm
LifeGuard
LifeGuard
I cant find this membrane in google (it does
not exist Smile )
7Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 7:55 pm
Ned
Ned
LifeGuard wrote:I cant find this membrane in google (it does
not exist Smile )
Thinking out loud... what about a thin plastic PET membrane like the one used in drink bottles. Can you cut a square from a flat packaging box that can be fitted between the piston and the brake pad.
Traditionally a stainless or copper shim is used but I have seen transparent ones.
You can try the PET shim and see if it cures it, then try ss or copper. I am sure that the brake specialist will have something that will fit or can be modified to fit.
8Back to top Go down   squeaking pads K100RS '87 Empty Re : Brake pad squeeling Mon Jun 14, 2010 11:00 pm
Dennis
Dennis
Careful here men, remember, there can be considerable heat transferred from the pad through to the piston. PET may become melted under these circumstances, I suspect that's why metal such as copper is used. Probably doesn't pay to "experiment" too much around brakes.
9Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Mon Jun 14, 2010 11:07 pm
Ned
Ned
Sure, I would only try it for a few km to see if this cures it and then proceed to cure the problem.
Moly paste may also be a good thing to try, but I suspect that any paste or grease would not last very long.
10Back to top Go down   squeaking pads K100RS '87 Empty Re: squeaking pads K100RS '87 Wed Jun 16, 2010 4:34 am
LifeGuard
LifeGuard
I bought this paste, (in Mercedes service - 1Euro for 2,5 ml ) and it works well... for now
This looks like aluminium temperature-resist paste
