1 inequalities on vacuum guages Mon Mar 20, 2017 9:42 am
Beamer
Hi,
I have just been sorting out a K100 that I bought AS-IS and which was running like a pig. After replacing a bad HT lead and a split inlet manifold it running much better: a good slow tick-over, though slightly erratic. Probably pretty serviceable.
However, on the vacuum gauges cyl 3,4 are notable lower than 1,2 ( each pair pretty much the same).
I have tried squirting auto-start around all the inlets and don't find any effect on the tickover speed, so I'm concluding that I've got the inlets air-tight now.
The bypass screws on the inlet don't really make much difference except that if I screw 1 &2 all the way home they rise a fair bit. Anyway, can't even it up with the screws.
I'm wondering whether this indicates leaky vales or messed about butterfly synchronisation. The inegality tends to remain as I raise the revs ( in neutral ). The marker paint is gone on the sync screws so I guess they've been messed with at some time in its life.
I know the wise folks NEVER touch the sync screws but if this has already been messed up, is it possible to get it set closer by shutting the bypass screws firmly home and adjusting the sync screws?
It seems to indicate that the butterflies are slightly more open on 3 and 4.
Any tuning experts care to comment on possible interpretations?
TIA.
TIA.
