1 waterless coolant Sat Mar 25, 2017 8:45 pm
gsxrjeff
they are using the stuff in jap bikes why not bmw's?
sorry meant to say local motorcycle garage use it when they do a coolant change on all of their bikes mainly jap bikes,they love it.BobT wrote:Because it does not cool as well as water does and you cannot top it up with water should you need to top up.
Can you tell us which Jap bikes are using it because as far as I know no car manufacturers use it.
Chassis number | 0025951 |
Vehicle code | 0504 |
Series | K589 |
Model | K 100 RT 84 (0504 ( 0505 ) |
Body type | K 100 RT 84 (0504 |
Catalog model | ECE |
Production date | 1985 / 01 |
Engine | 0514) |
Transmission | |
Steering | |
Catalyzer | NONE |
I've never tried the stuff - but to be fair, even the usual water based coolant struggles under those conditions if there isn't sufficient air flow across the radiator (by fan or motion) - I hit those high temps warnings in those same tunnels in "rush" hour traffic on Rosskko's neekid K100 a year or so back (fan wasn't kicking in).nods wrote:
As Rick said, it can't remove heat as effectively as water - I over heated in the M5 tunnel in Sydney on a hot day - had to pull over in an emergency break down bay and wait for it to cool down before continuing on. When I say over heated, I mean the temp gauge went to max then the engine warning light came on, so that was as far as I was prepared to keep the engine running at that point...... It's just the long tunnel with the hot air, stop/start traffic, and the lack of air flow (the air in the tunnel is moving with the traffic) where I've had a problem.
nods wrote: The Evans stuff never boiled though, and you never need to top it up. It just stays at the same level all the time.
Evans recommends using its costly proprietary coolant system cleaner by means of a high volume/low pressure flush before using its costly waterless coolant. After installation of the coolant, the water content must be <3% as tested by a refractometer or waterless coolant test strips. If it doesn't measure correctly the installation procedure must be repeated. I'd rather use the time to make a pizza or pooris, dough and all.nods wrote: you have to use the Evans prep fluid to absorb and remove all water in the system before adding the waterless coolant. Evans say even a small amount of water will reduce the cooling ability of the product.
Apparently Jay Leno is an advocate of the stuff for his collection of old cars.
Point-Seven-five wrote:Somebody, please tell me why I want to put an expensive coolant that isn't as efficient as an ethylene glycol/water mix in my bike.
That rings a bell from my reading a couple of years ago Rick - that was one of the draw cards - having no pressure in the system. I think I remember running the engine up to normal operating temp (in the garage) without the radiator cap on. There's a bit of propaganda on the Evan's website about the fluid not forming miniature gas bubbles at the surface of the cooling passage material due to "boiling" (a property of water) and hence being better in that regard. It all got too technical for me and I just liked the anti-corrosion, the "no pressure", and the "use for life of the engine" properties.RicK G wrote:So this stuff doesn't expand when it gets hot?
There would have to be a hell of a lot of evidence of this stuff before I'll convert.
Series | K589 |
Engine | 0514) |
Transmission | |
Steering | |
Catalyzer | NONE |
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » waterless coolant
Similar topics
