Number of posts : 7942
When I wanted to paint the bars on my RT I ordered used ones from Motorworks which I intended to recoat and then install. They were in such good condition with one little mark I decided it fit them...but they came off a K with heated grips. The ends are different, mine has bar ends and no heated grips. The ones for the heated grips have a cut out and chances are your existing bars don't have the cut out.
On the plus side I believe the loom is already in place and all you do is plug them into the connector. There should be a switch with them ?? for installing in place of one of the blanks at the impact pad where the ignition is? The Motorworks picture for the heated grip sets shows the switch for the impact pad and also the wiring in the photo of the parts.
On the portal page of the forum there is access to interactive wiring diagrams which should help.
You will need tank off and probably loosen off the impact pad with the ignition in it. I find it helps a lot to take off the screen and the cross panel under it when accessing those areas, all held on by the 8 screen screws.
1971 Yamaha 125 YAS-1
