51 Re: Clutch Problems? Wed Feb 01, 2017 9:41 am
I firmly believe that you will probably need to remove the gearbox if either is wrong.
Firstly try to remove the clutch pushrod out the back of the gearbox. If it will come out then the pushrod probably is usable but check it for straight with a straight edge ruler.
If it wont come then you will have to remove the gearbox to replace or straighten it. I would attempt to straighten it because if it is bent it is unusable and you have nothing to lose.
If it does come out then the thickness of the plate is probably the cause. The plate being 1.5mm thicker would possibly make the centre of the diaphragm spring higher by anything up to 6mm maybe higher so causing the pushrod to make the throw-out bearing sit further back and then the clutch actuating arm would probably not meet the bearing correctly causing it to jam in after the first time you pull the clutch in.
