1 Oil pump gear installation Wed Dec 14, 2016 6:16 pm
TIV
I am rebuilding my oil/water pump. The only thing I´m not sure about is this: If I understand the function of the pump correctly, the narrow part of the water seal turns with the gear, i.e. the narrow end should be fixed around/to the shaft of the gear.
I can´t find anything about this in my Haynes manual which has probably been made before the new type of seal was implemented. Should I oil the shaft before I pull it through the water seal or should I pull it through dry? I think (from memory) that the inside of the narrow end of the seal has a blue goo inside it to fix it to the shaft.
These articles have been very helpful:
http://www.ibmwr.org/ktech/water-oil-pump-rebuild.shtml
http://www.ibmwr.org/ktech/water-oil-pump-rebuild2.shtml
http://hrsbstaff.ednet.ns.ca/bvogel/K100/oil_pump/oil-pump-seals-replacement.htm
1936 Harley Davidsson 750 (sold), 1964 BMW R69S (sold), 1973 Suzuki RM400 (sold), 1972 Triumph Bonneville (sold), 1971 BSA Thunderbolt (sold), 1972 BSA Lightning (sold), 1977 Yamaha XS650 (sold), 1971, BMW R75/5 (sold), 1973 BMW R75/6 (sold), 1984 BMW R100RT 1992 Yamaha FJ1200 ABS (sold), 1990 Harley Davidson Electra Glide (sold)
1990 BMW K75RT Ex-Police (owned now)
2004 BMW R1150RT iABS (owned now)
Cheers TIV
