1Back to top Go down   Parking lights not working... Empty Parking lights not working... Thu Jan 05, 2012 9:35 pm
voggsson
Both front an back parking lights do not work when ignition is switch on and/or bike is running. Works fine if ignition is switched to "P" (park). The headlight works fine. Could this be a battery thing?
Do you have any ideas?
2Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Thu Jan 05, 2012 9:43 pm
what about the main lamps ? do they operate ?
several possibilities ....
right hand switch mechanism has corroded terminals in the switch mechanism (in the park position )
corrosion on connectors from handle bars ....under tank
there will be others with some good info also
welcome to the forum voggsson
3Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Thu Jan 05, 2012 9:56 pm
Welcome Voggsson
is your Bulb warning light on at all (red triangle on instrument cluster)?.
Clean all connectors (volcanic ash wouldn't do it any favours).
If you go to the introduction section and tell us about yourself and your bike
you will be able to get into the electrical fault finding charts.
Good luck
4Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Thu Jan 05, 2012 9:57 pm
voggsson
The main lamps work fine, but not the front and rear parking lights, does not matter if the headlight switch is in the parking light or runnig light mode.
I'm doing a light restoration, and this is only one thing on the check list. Wink
Thank. Smile
5Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Thu Jan 05, 2012 10:06 pm
voggsson
We washed all the ash away a long time ago. Smile hehehe
I'll check the connectors and clean them, and I'll check out the introduction section.
Thansk for the warm welcomes.
6Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Thu Jan 05, 2012 11:10 pm
One thing to check is the bulb monitoring unit in the relay box it gets its power from two different sources depending which mode the key is in.
7Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Fri Jan 06, 2012 12:34 am
voggsson
Is tha the green one, RELAY FOR FLASHER 61311459224?
8Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Fri Jan 06, 2012 12:58 am
voggsson wrote:Is tha the green one, RELAY FOR FLASHER 61311459224?
No not that one see the diagram below
Parking lights not working... Relay_10
This unit monitors the park, tail and stop lights. If any are faulty it lights the red light with the triangle on the instrument panel.
9Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Fri Jan 06, 2012 2:50 am
The right hand undertank wiring connector has a green-blue wire on pin 3 coming from fuse 7 that feeds power to the righthand Eurolight switch cluster for parking lights and headlights. Parking lights power output is pin 7 on that same connector and is a grey-blue wir; while headlamp power should feed out pin 4 and have a white-yellow wire. When the righthand switch is in either the park or headlamp positions, there should be power at pin 7 (relative to ground). If your bike shows power on pin 3 with the ignition on but no power on pin 7 in either Eurolight switch switch position, then the fault lies in the righthand switch cluster. It could be corrosion or poor soldering within the switch assembly. If there is power on pin 7 in either switch position, then the fault lies further along the wire loom and you'll have to do some tracing.
10Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Fri Jan 06, 2012 9:27 pm
voggsson
Thanks for the advice, I'm gonna try this when I start tearing the bike apart.
11Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Fri Jan 06, 2012 11:33 pm
voggsson wrote:Thanks for the advice, I'm gonna try this when I start tearing the bike apart.
I do hope you will remove the screws, nuts and bolts first. What a Face
12Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Sun Jan 08, 2012 9:59 am
Parking lights not working... 44271
13Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Mon Jan 09, 2012 10:28 am
voggsson
Ok I checked the switch and it's ok, so the problem is deeper than that. Sad
14Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Mon Jan 09, 2012 10:57 am
Check the conductivity between terminal 58A (grey wire) and 58E (grey/blue wire) at the ignition switch.
Could be that your ignition switch needs to be dismantled and cleaned, or you have a bad connection
at the pigtail.
Here is a "how to" dismantle the ignition switch, if that is needed.
First you could try a jumper between the solder points, to confirm it`s at that place your problem is.
BTW if you ain`t got instrument illumination either, the problem is closer to the light switch.
Last edited by Inge K. on Mon Jan 09, 2012 12:05 pm; edited 3 times in total (Reason for editing : Adding info.)
15Back to top Go down   Parking lights not working... Empty Re: Parking lights not working... Sat Apr 07, 2012 4:50 pm
voggsson
Inge K. wrote:Check the conductivity between terminal 58A (grey wire) and 58E (grey/blue wire) at the ignition switch.
at the pigtail.
Ok, I checkd this and everything is working fine on the switch side it seems.I checkd the pigtail end and it seems to be fine.
Maybe I'll have to doubble check the switch again.
