1 K100 1985 tiny bearings bottom of the clutch case area Sat May 30, 2020 4:23 pm
junitiger1
Last edited by junitiger1 on Mon Jun 01, 2020 1:10 pm; edited 1 time in total (Reason for editing : Photo of bearings)
Laitch wrote:¿Cuantas bolas encontraste?
Laitch wrote:No hay rodamientos en el paquete de embrague. Are you sure these are not fine metal particles en vez de bolas? We need photographs, so keep posting until you can submit some.
Dai wrote:You need one more post first (five in total) before you can upload pictures. This rule is to slow down spambots.
They are most likely bits of debris altered as Martin described in Reply #16. They are not bearings. The pressure plate does not have bearings. They might be bits of metal fallen from the pressure plate. Post a photo of the pressure plate area where you believe this debris was attached. Your photos are good quality.junitiger1 wrote:Here is another foto of the bearings, thank you for the information
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » K100 1985 tiny bearings bottom of the clutch case area
Similar topics
