oh ! chris ...let me get this straight.... you are going to just repeen the rivetts so they mate up tight ?
gooly gosh this could be a problem .
the rivetts rely on their "sheer strength" of a close fit between the hole and the rivett width , which should be a close a fitt as possible .
having elongated holes from wear , you would only be compressing the rivett clamp action again and under load you would find the rivetts would soon be making noise and movement really quickly .
it would be verry adviseable that, now that you have the problem ..in hand so to speak that you re-drill the rivett holes to get rid of the elongated hole issue ...maybe a hole just slightly bigger than the elongation of the ones you have already .. this would be totally dependant of you finding some "stock"/metal to replace the rivetts with a width of the hole that you need to drill to remove the elongated hole ...worst case solution would be to buy/get some new rivetts so that the metal is new ...not anealed and worn at the critcal joint interface .
i know repeening the rivetts would compress/distort the metal sufficiently to hopefully take up the gap ...but not an ideal solution
in my mind, if you had one "thou" of gap difference between the rivett and hole thickness/width ....that would be way too much
