1 Help me start this bike - 93 K11RS Sun Sep 18, 2016 11:58 pm
I bought an abandoned 93 RS for parts the other day. (I bought it legally from a real shop and its abandoned status is properly documented with the Dept. of Licensing.) It's got 105K miles and has seen some better days but it does have a decent Works Performance shock and Staintune exhaust.
So far:
- The cluster lights up and the fuel pump primes like it should when the ignition is turned on. (With a screwdriver. )
- The inside of the tank is very clean and the gas looks good.
- The clutch cable is broken but when I pull in the clutch lever and hit the start button the starter relay clicks so I know that's working. But that's all it does.
- Aside from the cluster, neither the headlight nor tail light come on when it is turned on.
- I replaced all of the little black relays thinking the load shed might be bad but that didn't help.
- Also swapped in a new starter relay.
- When I tested the voltage on the top of the starter it reads 12V even when the starter button isn't pushed. Shouldn't that only be 12V when the starter relay is engaged?
- I'm pretty sure the transmission is in neutral by shifting the lever but the gear indicator is stuck on 3 so that switch is probably shot.
Given the 12V reading at the starter I'm thinking maybe it needs a new starter.
Since it's a parts bike I don't plan to spend a whole lot more time and effort on it but I'd like to get it running just for the heck of it.
Anybody got any clues on this puzzle bike?
So far:
