1Back to top Go down   Instruments Empty Instruments Mon Sep 19, 2016 3:59 am
nino
Hello, my km (mileage) counter stoped working both total an daily. Speedo works as usual. Where to look?
2Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 4:13 am
the gears nino
there are many post about this ...usually its the 3rd and 4th cogs
but the little drive gear sometimes split as well
good luck
3Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 4:22 am
nino
Thanks Charlie, is it complicated repair?
4Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 4:35 am
no not hard at all nino ...but getting the right gears is the issue
I'm sure living in Europe should be easier than out here down under
Instruments 2014-010
5Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 6:55 am
nino
Charlie, is it possible just to change gears as complete unit because I have one spare speedo. I am horrified about possibility to change gear by gear?
As matter of fact I have mileage gears not kilometers.
6Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 7:28 am
not sure nino ....to my way of thinking there is a slight difference in the odo ..versus the speedo ...the speedo has been graduated with different locations for the mph than the kph ...but the gears may have a teeth difference  to make it all accurate
sorry I don't have more experience with the mph odo gears ...
there are many posts in the forum if you use the search thingy
7Back to top Go down   Instruments Empty Re: Instruments Mon Sep 19, 2016 12:58 pm
nino
Broken first double gear just like on your photo. Mine is orange (for kmh) and when I compared to the set in mileage which I have in garage I found that mileage gear was smaller in diameter.
Anybody know the source for plastic gears for km/h
