1Back to top Go down   Timing chain mark Empty Timing chain mark Wed Sep 14, 2016 1:17 pm
nino
Hi, I have a question about K 100 timing chain. I bought new timing chain from Motobins and ready to change. I noticed that one joint was in color of copper. Is it a mark? If yes where goes that mark?
Regards
2Back to top Go down   Timing chain mark Empty Re: Timing chain mark Wed Sep 14, 2016 1:53 pm
No worries on aligning the chain to anything. It's the gears coordinating that are critical. Be sure the two timing gear arrows are pointing the way they're intended, and the crank gear as well.
3Back to top Go down   Timing chain mark Empty Re: Timing chain mark Wed Sep 14, 2016 2:08 pm
nino
Thanks for quick answer
4Back to top Go down   Timing chain mark Empty Re: Timing chain mark Wed Sep 14, 2016 11:55 pm
Also, before you remove the old chain, for a K100 you need to ensure that zyl#1 is somewhere close to tdc on the compression stroke (#3 for K75 I think). This ensures that the cam shafts don't move when the chain is removed.
 Timing chain mark Austra12    Fuel:  95 Octane
5Back to top Go down   Timing chain mark Empty Re: Timing chain mark Thu Sep 15, 2016 1:58 am
Good tip, Mr Holister!
6Back to top Go down   Timing chain mark Empty Pics for you to use as a guide Mon Oct 10, 2016 1:58 am
SniperX
SniperX
In this picture you can see the cam sprockets lined up. The little U shapes at the top of both cam sprockets should be as close as possible to the top of the sprocket as shown. Timing chain mark Cam_sp10
As well, the crank has a PIN on it which is lined up as shown when the cam sprockets are aligned as shown in the previous picture. The three holes in the crank snout are for the screws that hold the timing plate on.
Timing chain mark Crank_10
After lining all these up BEFORE you remove the old chain, you then follow the manual as closely as possible for the correct removal of the timing guides and tensioner. If you need further help since I just did mine a couple months ago I'll be glad to add more information. If I don't quickly respond, email me a reminder and Ill come back here and answer. kevin0232@gmail.com
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
7Back to top Go down   Timing chain mark Empty Re: Timing chain mark Wed Oct 12, 2016 2:32 am
SniperX
SniperX
Holister wrote:Also, before you remove the old chain, for a K100 you need to ensure that zyl#1 is somewhere close to tdc on the compression stroke (#3 for K75 I think). This ensures that the cam shafts don't move when the chain is removed.
Or you can remove the covers (cam cover, bottom end cover, then timing cover) and align the cams and crank sprocket dead up then scribe marks for all and remove the chain and related components.
