1 Newbie not starting question Sat Oct 08, 2016 2:17 am
corran57
Hi Everyone,
Longtime stalker first time poster. I have a 84' K100, was running well until i lost fuel pump and injectors (standing to long, rubber baffle melted).
I have replaced pump and injectors and she won't start. Here's the trick:
After kicking it over a bit I can disconnect the fuse for the fuel system and it will run from the fuel in the cylinders. Also if I disconnect the Fuel pump she will run.
I would be thinking Fuel Pump, but it is working so the problem would be that it is flooding, but there are injectors. Maybe regulator?
Other conditions, air box is out ATM, though that is new so i could replace fuel lines.
Anything else you need to know?
Would love to hear your thoughts.
Jas
- Fuel Pump is working
- Injectors working
- we have spark
- lines new and cleaned checked
- new fuel
- Tried a second working EFI compt
Jas
