1Back to top Go down   Fuel pump issues K100 RS Empty Fuel pump issues K100 RS Tue Sep 13, 2016 9:30 am
andyldean
andyldean
Recently purchased a k100 Rs which had been a none runner for the last few years.
Traced the problem to the fuel pump not receiving power from the relay.
added and additional wire from the rear of the relay direct to the pump and the bike runs and all is great. so I decided to renew the wire and rewrap the loom.
Only to discover that the wire in question runs to the back of the clocks and not direct to the relay as indicated in my wiring diagram.
What signal does the instrument panel send to the fuel pump to initiate start?
Its no good rewiring the fuel pump to the back of the relay when the signal sent by the clocks is the problem.
Does anyone have a wiring diagram that may help?
Could it be anything to do with the abs ?  Thanks in advance.
1987 K100RT (cafe racer)
1991 K100RS (soon to be my sons cafe racer)
2Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:30 am
On a 4V K100RS the fuel pump relay is triggered by a ground signal to the blue/brown wire from the Motronic.
(Assuming the side stand is up and that switch is working. 12V+ to the fuel pump relay on the green/red wire.)
3Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:32 am
Another possible cause of the fuel pump not getting power is a flaky connector for the fuel level sender.
4Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:35 am
andyldean
andyldean
the fuel level sender could be an issue as the tank was left for a long time with bad fuel in it.
The inside of teh tank is reasonably crapped up.
Is there a way to bypass this fuel level sender?
5Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:36 am
andyldean
andyldean
the feed to the relay looks good its the output which looks like its at fault.
6Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:39 am
andyldean wrote:Is there a way to bypass this fuel level sender?
You can run wires directly to the fuel pump through the gas cap. I had a guy come by my house once who had done that.  Crude but it did work.
(The smaller terminal on the fuel pump is 12V+, the larger terminal is ground.)
7Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:42 am
8Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:45 am
andyldean
andyldean
no its not the tank connector its definetly at the instruments.
Does anyone have a pinout diagram for the fuel tank connector?
9Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:54 am
andyldean
andyldean
the wire that feeds the pump from the connector under the tank is yellow and white.
this runs to the back of the instrument panel to the pin which looks like its labeled gear position indicator. also yellow and white.
cant see why none of this is illustrated on the wiring diagram.
It makes it hard to work around.
10Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 10:54 am
FLS connector:
Brown - ground
Green/white - fuel pump 12V+
White - to low fuel lamp in instrument cluster
Yellow - to fuel gauge
11Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 11:00 am
andyldean wrote:the wire that feeds the pump from the connector under the tank is yellow and white.
The fuel pump has nothing to do with the instrument cluster.
The only wire from the FLS to the cluster is a white wire for the low fuel lamp.
There are three wires for the GPI in the cluster:
yellow/white
yellow/black
yellow/blue
Those all come from the gear position switch on the back of the transmission.
12Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 11:03 am
andyldean
andyldean
very strange because the output from the relay has no continuity o any pin on the fuel tank connector
13Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 11:20 am
andyldean
andyldean
Solved.  The previous owner when trying to get it running must have mixed the two connectors around.
The tank connector was plugged into the gpi.
You made me think with the wire colours and I have just checked.
I thought it was odd when I took the tank off my rt and the connector pins disn't fit neatly.
Thanks again.
14Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 11:22 am
The green/white wire from the 87 pin on the fuel pump relay goes to the FLS connector in order to power the fuel pump.
15Back to top Go down   Fuel pump issues K100 RS Empty Re: Fuel pump issues K100 RS Tue Sep 13, 2016 11:36 am
andyldean
andyldean
yes all good now.
Its great being able to bounce ideas around on a forum.
As soon as you gave me the colours for the GPI my light bulb lit and I disapered into the shed with my multi meter. :-)
