1Back to top Go down   K100RS (16v) top yolk Empty K100RS (16v) top yolk Sun Aug 28, 2016 10:35 am
CraigNZ
CraigNZ
Hi,
Am doing a bit of a cafe\custom job on my K100RS (16v). Fitting a round headlight and another dash, drag bars or clip on. The ignition key is housing is all wrong for what I am doing, far too high.
Will something off another BMW model fit?
1991 BMW K100RS
1999 BMW R1100S
2Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Sun Aug 28, 2016 11:52 am
craig ...some have modified the yolk to fit the ignition switch in there ...looking quite sweet if I do say so ...
keep looking mate there are some good solutions for what you are attempting
3Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Mon Aug 29, 2016 8:15 am
CraigNZ
CraigNZ
Will do Charlie, thanks for the reply
1991 BMW K100RS
1999 BMW R1100S
4Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Mon Aug 29, 2016 6:07 pm
Because, as you know, the 16V models used a cast in ignition switch housing (that sits too high if you're customising and/or using clip-ons) you can machine it off and use one of the rubber mounted handlebar holes for its placement, instead. The electrical portion of the switch is the same between models and there's usually enough lead length that you can place it somewhere round the triple clamp. You'll be giving up your steering head lock and will have to find the 'mechanical' part of the ignition switch from a an earlier K as the 16V version is the bit that is too long inside that cast housing. I stayed with the cast piece and used ProTaper 'bars and their riser blocks (for the fat part of the 'bar) with the standard rubber mounts.
K100RS (16v) top yolk Imag2812
This image is the unfinished view. The Trail Tech Vapor dash will be encased a slim aluminium housing and slightly off-centre.
5Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Tue Aug 30, 2016 2:38 am
Lest we get egg on our collective face, we should be aware that this is no yolking matter.
Just a yoke. Wink
6Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Tue Aug 30, 2016 1:18 pm
K100RS (16v) top yolk Images?q=tbn:ANd9GcSijjBMXteS72UnnrW3LYx6B96_uaMVPkT1TK9RrGHlgzBimh7FVQ
All this laughing is making me eggs-hausted
 K100RS (16v) top yolk Austra12    Fuel:  95 Octane
7Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Wed Aug 31, 2016 1:48 am
CraigNZ
CraigNZ
Thanks for the replies.
Is this mod something I could do myself with a good old angle grinder.....go on egg me on to have a go Very Happy
Where did you get that clock Two Wheels?  Looks good. Have just gone for a cheap one off Ebay (its the one on a forum posting on https://www.k100-forum.com/t8232-electrical-trouble-mounting-aftermarket-digital-speedo)
Did you fit the Cafe type seat base?
Craig
1991 BMW K100RS
1999 BMW R1100S
8Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Wed Aug 31, 2016 1:54 am
CraigNZ
CraigNZ
K100RS (16v) top yolk Img_0010
1991 BMW K100RS
1999 BMW R1100S
9Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Fri Sep 02, 2016 11:42 pm
CraigNZ wrote:Thanks for the replies.
Craig
Trail Tech are a company based near Vancouver, Washington. Trail Tech  They've been making digital dashes for dirtbikes and such for yonks. I'm using their model called they call the 'Vapor' with the dash surround, eventually, so I can have a few idjut lights.
My Big Block's seat base in fibreglass (seat foam and covering made by another) was a custom one-off made by a mate in Tacoma, WA.
K100RS (16v) top yolk Imag2610
10Back to top Go down   K100RS (16v) top yolk Empty Re: K100RS (16v) top yolk Tue Sep 06, 2016 5:14 am
CraigNZ
CraigNZ
Nice looking bike !
Nice seat, not chopped the frame at all?
Is the battery still down in the bottom of the frame?
1991 BMW K100RS
1999 BMW R1100S
