1 K100 K75 Clutch Housing/Carrier Fri Jul 22, 2016 5:57 pm
G'day all Forumers. A stupid question from someone less knowledgeable. Are the clutch housings/carriers for the K100 and the K75 interchangeable?. As far as I can see, the main difference between the two (according to Clymer pictures) is that the 100 carrier has three holes and the 75 has none. I suppose because there are no holes in the 75 carrier, they tell you to use a special tool to hold the carrier so the 30mm nut can be removed. Thank you all in advance. Any info much appreciated. Cheers Tom
