1 Simple bevel box locking tool Wed Feb 15, 2012 4:44 pm
Today I have been working on my spare rear drive with a view to run the drive splines in oil.
While I was washing out the area around the spline, I found that the bevel gear locking nut was only fingertight (the bevel box was from e-bay, so I don't know the history). Not having the elaborate BMW service fixture, I had to come up with a device to lock the drive so that I could tighten the nut to the requisite torque.
This is the result:-
Do you like the tablecloth?............ I've been learning from OG!
The bar size is arbitrary, I found a lump of 20mm square, but it must be big enough to be gripped in a vice.
Two 8mm holes are drilled at 70mm centres and a 10mm hole 77.5mm from the middle hole.
A 20mm long 10mm bore spacer completes the tool.
Ignore the steps in the bar, I had used it for another jig in the past.
