1 Low beam headlight not working! Sun Apr 24, 2016 2:13 am
gabriel
Hi all
I have a 1984 Bmw k100 which is running well except for the headlight.
The bike is in reasonable condition. There is no rust and the wiring is in good condition.
I did a visual check of the fuses.
The high beam works when I press down on the yellow switch on the left hand side. I have to keep the switch pressed down for the high beam to work. If I push the yellow rocker switch upwards, the high beam does not work.
The park light also does not work.
The rear park light is fine.
I haven't checked the relays? Or cleaned the left hand side switch.
All replies appreciated.
Gabriel
Gabriel
